Results 1 to 2 of 2
Thread: Wagner Tuning Quick Factory Tour + Intercooler Build Process: Concept To Completion
    Jan 2017
    Las Vegas
    Talking Wagner Tuning Quick Factory Tour + Intercooler Build Process: Concept To Completion
    Wagner Tuning Quick Factory Tour + Intercooler Build Process Concept To Completion
    Credits to Micky Slinger for the interview
    HOW IT WORKS
    After air is taken in by the intake, that cool air is then heated when the turbo has compressed/ charged it. If that hot air made it to the engine after that, the heat soak would be real, and so would the decrease in the engineís efficiency and its ability to make power. This is where an intercooler comes in. Cooling that charged air (why they are sometimes called ďcharge air coolersĒ) from the turbo cools intake and exhaust temperatures, which makes your engine and turbo last longer, as well as makes your engine more efficient at making power, therefore increasing horsepower and torque!
    If youíre experiencing heat soak, youíre being robbed of power and hurting your engine.
    WHATíS THE STORY BEHIND WAGNER TUNING? HOW DID THE COMPANY GET ITS START AND HOW DID INTERCOOLERS BECOME ITS SPECIALTY?
    Wagner Tuning originated out of a speed shop that father, Werner, and son, Carsten, Wagner started in 1994. After a period of time, Carsten Wagner started to venture into performance products for Audis. In 2002, Carsten established Wagner Tuning with his first intake manifold. From there, a series of exhaust manifolds followed and became sought after in the European market. In 2007, Wagner Tuning produced our first performance intercooler and is now a leader of intercooler development in the performance aftermarket
    WHAT SETS WAGNER TUNING APART FROM OTHER INTERCOOLER MANUFACTURERS?
    When Wagner Tuning started to have interest in the intercooler market, we decided to develop an intercooler for specific vehicles and design it to perform, removing all bottlenecks that would cause restriction. We produced an intercooler that works in conjunction with all other cooling elements of the vehicle, like radiators and A/C condensers. We also increased the size of the intercooler compared to the OEM intercooler, increasing the amount of air volume and facial cooling surface. Development is what we do!
    HOW DOES A WAGNER TUNING INTERCOOLER GO FROM A CONCEPT TO A COMPLETED PRODUCT ON A CUSTOMERíS CAR?
    First, we research the vehicle and its potential to perform. Most turbo vehicleís restrictions are the OEM intercoolers not being large enough or efficient enough, so thatís where we start our research and development to design an efficient unit. We 3D scan the location of the factory intercooler and use all the space that is available to be used for a newly developed intercooler unit. After state-of-the-art testing, we produce a prototype and run a true vehicle test. After it has been proven to perform as developed, we start production and supply the market.
    DOES WAGNER HAVE ANY EXCLUSIVE MANUFACTURING PRACTICES?
    Wagner Tuning was the first to produce an intercooler using cast aluminum endtanks. This is one our first exclusive ways of producing an intercooler, and soon the competition followed. We also coat our intercoolers to protect them from the elements.
    COOL TIPS
    When deciding on an intercooler, there are a few things to take into consideration before you can make the right choice for your application.
    ROOM
    How much room do you have for an intercooler? If youíre looking to upgrade to something bigger, look at two things: how wide you can go and how thick you can go. Wider and thicker intercooler cores are the most efficient at using air flow, so if you canít go wide, go thick, and if you canít go thick, go wide!
    BLOCKAGE
    Odds are, in most applications, the intercooler is going to sit in front of other cooling components, namely your radiator. If you cheaped out and got a brick of an intercooler or got something that doesn't measure up to the air flow you need, you could be blocking or stealing cold air from your rad and increasing coolant temperatures, which isnít rad.
    RATING
    Pay attention to what the pressure rating is on your intercooler, and donít choose something below your needs. If youíre trying to run more boost than what your unit is rated for, youíll blow the welds on your endtanks. Then no one is having fun.
    WHEN SOMEONE IS LOOKING TO ADD AN INTERCOOLER OR UPGRADE THEIR EXISTING SETUP, HOW CAN THEY TELL WHAT KIND OF CORE THEYíLL NEED FOR THEIR POWER LEVEL?
    There have been a lot of rumors and stories about the benefits of each core system. Wagner Tuning, being a developer and manufacturer with over 11 yearsí experience in performance intercoolers, would like to share our knowledge on this topic.
    Basically, when it comes to core systems, there is no good or bad; there are only characteristics attributed to each version that have benefits or drawbacks for each given situation.
    The BAR & PLATE core is a heavy system thatís "sluggish" in taking temperature. This is great for short, full-throttle situations you see on the quarter mile. For longer rides in the summer, on a hot highway or race track, the greater mass in material retains more heat over time that can't be released effectively. Manufacturing a bar plate core is uncomplicated and less expensive because there is no special tooling needed.
    The TUBE & FIN core is lightweight system that absorbs temperature quickly. The maximum stock temperature is below the bar plate core. This core is not as efficient in performance on the drag strip, but is ideal for not holding heat on the highway or racetrack because it recovers much faster from full throttle compared to bar plate construction. Manufacturing a tube fin core is more complicated and requires special tooling, making it more expensive to manufacture.
    There is no evidence that one or the other is more pressure resistant. Pressure resistance of both core systems relies on the build quality. Wagner Tuningís tube fin core can handle over 100 psi, depending on the application.
    We have two different series of intercoolers: the Performance Series, which is a bar and plate center core, and the Competition Series, which is a tube and fin center core. We originally started with the Performance Series, and as we progressively started to improve our product line, we developed a better solution to handle and create more power.
    Each series is offered in an EVO1 or EVO2 intercooler. The difference is the size of core. A bigger core surface can receive and adapt to more air volume and heat. The EVO2 is always our recommendation when the turbo is running at its limit and producing very hot outlet temperatures, but you can also run an EVO2 system with light ECU tuning with the option to increase performance with a more aggressive tune in the future.
    BAR V.S. TUBE
    When choosing an intercooler core, youíll be met with two choices for design: bar and plate or tube and fin. The main differences between the two are the facial surface structure, a.k.a. the space between the vents thatís either flat (bar) or round (tube). When air hits the surface of the intercooler core, it slips through the vents, but then has to interact with the solid bar or tube in between. When air hits the bar, itís hitting a flat surface head-on, so the air deflects, while a tube surface is extruded and rounded, which channels the air towards the vents and increases airflow. Both are good choices, but if youíre looking for that extra edge, a tube and fin core is the way to go.
    WHEN IT COMES TO THE INTERCOOLER CORE, IS BIGGER ALWAYS BETTER?
    Yes, to a certain extent! Some builders think that because they have built a huge intercooler that it will perform better, but thatís not always the case. There is a point where being too big and having too much air flow can cause problems. Thereís a certain air flow formula that needs to be considered to make sure that things like pressure drop doesnít occur and the turbo isnít working too hard to supply enough air flow to actually produce power.
    Jan 2017
    Las Vegas
    N55 Downpipe picture provided by Myslow235i
  1. Wagner Tuning Downpipes & Intercoolers - Special Forum Members Prices!!
    By mike@XPH in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 04-03-2019, 05:49 PM
  2. Wagner Tuning EVO III COMPETITION INTERCOOLER Now Available *** New Product ***
    By mike@XPH in forum 1 Series & 2 Series (E81, E82, E87, E88, F20, F22, F23)
    Last Post: 09-19-2018, 11:21 AM
  3. Wagner Tuning EVO III COMPETITION INTERCOOLER Now Available *** New Product ***
    By mike@XPH in forum 2006 - 2012 (E90, E91, E92, E93)
  4. :: ECS Tuning :: Wagner Tuning now Available! | Intercoolers, Downpipes, and More!!
    By ECSTuning in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 10-09-2017, 05:15 PM
  5. Replies: 0
    Last Post: 02-08-2017, 05:33 PM
