Page 2 of 5 FirstFirst 12345 LastLast
Results 26 to 50 of 116
Thread: Nate's S62 Engine Refresh/Rebuild Thread
  1. #26
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by philly98540 View Post
    Nice progress Nate. Not sure about those threaded bushes. Maybe an S62 expert will chime in.
    I can't find much information on them beyond the info in TIS. They thread into the top of the main bearing cap (with the engine upright).
    I assume their purpose is to absorb any irregularities in the block and to keep the block square, like a corner balancing alignment. It keeps the torqued outer bolts from stretching the block. Here's what BMW has to say:
    Attachment 649976
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  2. #27
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Is choosing the correct bearing sizes to fit the new crank easy to figure out? Color codes or something?
    I believe I understand things a bit better now. Assuming a stock crankshaft, the stock bearing "yellow" size goes into the crankcase side of the main bearings. The other side, the cap side, requires precise measurement to select a "color" code. The size of the journal dictates what "color" bearing to order. The crank is marked with paint from the factory, but after hundreds of thousands of miles there's no way the paint is still intact. I'll have to get the crank mic'd and order the appropriate bearings.
    Quote Originally Posted by 98OrientBlue View Post
    Just catching up on this thread... wow what a cautionary tale. As well cared fore as your car obviously was, these cars can still just go ka-bluey at any time. Hats off to you for tackling the rebuild. Best of luck!
    More of this car's backstory can be seen in this video:
    https://www.youtube.com/watch?v=9BD0kT2mDXY
    Nate J.
  3. #28
    Sep 2014
    Bay Area, CA, US
    1998 BMW 540i/6
    Oh dude... you just got the car. Man, sorry about that.
  4. #29
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Quote Originally Posted by computiNATEor View Post
    Sounds like you got this figured out! A proper measurement with the correct tools will ensure success. Don't trust platigage. Its only good for a bump check IMO.
    Are you planning on doing anything with the pistons? Getting new rings. or cleaning the ring grooves?
  5. #30
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Just cleaning. With the nigh on zero oil consumption, there’s no reason to mess with them.
    Nate J.
  6. #31
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Why does an S62 water pump cost $400 on the low end?! WTH! Ugh. Ouch.
    Nate J.
  7. #32
    Apr 2009
    NW Ontario
    '05 M3, '02 525iT
    Great job so far Nate! I'm really enjoying watching the progress and it's nice to see someone else tackling something similar.
    As for the water pumps, they used to be around $250 but went on back order and jumped up in price about a month ago
  8. #33
    Middle of a corn field
    E39 hamster/ruberbandPWR
    https://www.ecstuning.com/b-laso-par...511407113~lso/
  9. #34
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by Jason5driver View Post
    Right, I saw that, but is that the OE part?
    Nate J.
  10. #35
    Supposedly, Laso and Saleri are the same.
    Saleri is OE.
    I would call ECS.
    http://www.m3forum.net/m3forum/showthread.php?t=448299
    https://www.m5board.com/vbulletin/e3...so-vs-oem.html
  11. #36
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Saleri is OE.
    I would call ECS.
    Cheers, good to know. Thanks!
    Nate J.
  12. #37
    If it were my car, I would have no worries about putting in a Laso water-pump.
  13. #38
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Alright, so I finished up the long spreadsheet for parts, part numbers, retailers, brands, and prices.
    Current numbers come in at 402 individual parts, 146 part numbers, and a grand total of $4915 for everything I can think of, excepting machine shop work and the cap-side main bearings because I still need to have the crank mic'd.
    Wow. I am replacing just about every single piece of rubber or plastic I can find, but jeez. There are some parts that are just expensive, like the dual mass flywheel and the timing chain tensioners.
    Nate J.
  14. #39
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Wow is right, M5 parts cost, even M5 parts that are exactly the same as 540 parts cost more. They change the p/n so they can jack up the price.
  15. #40
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    You wouldn't happen to have a list of those, would you? haha.
    Nate J.
  16. #41
    JimLev's Avatar
    Sundance Mesa, NM
    No. A few years ago I bought a complete M5 rear subframe with everything attached. I had to buy it that way to get the LSD and driveshaft. As I was parting out the parts I didn't need I was looking at the ones that were the same as my 540.....different p/n and higher price. I still have both rear wheel carriers....hint hint.
    The part I remember the most was the rear subframe, it was exactly the same, just had an M5 sticker on it with a different p/n.
  17. #42
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I'm practicing measuring on my old crankshaft with micrometers from everyone's favorite cheap Chinese tool store. They're accurate to .0001, which is good-ish for my purposes, but they are unfortunately in inches. Anyways.
    The crank main bearing journals have two different specs listed in NewTIS:
    "bearing point 1"
    "bearing point 2-7"
    I made a spreadsheet to convert the numbers to something readable from my calipers.
    Now besides the fact that the S62 only has 5 journals (I assume that "Bearing point 6 and 7" are for I6s, and the TIS documentation was not updated to reflect a V8), it is odd that the #1 journal specs are .02 smaller than the rest of the journals. My measurements don't bear that out. The first journal is maybe 0.0004 smaller. They're pretty consistent across the crank:
    But even with the published numbers, the "radial crankshaft bearing play" doesn't change. Allowable oil clearance is 0.025-0.050.
    This seems odd to me. Can someone explain why it's like this? Two different specs for a journal that's not very different from the others? In any case, if I were to be installing this crank again, I'd just use yellow bearings all the way across, and the front oil clearance might be a smidgen tight, correct?
    Nate J.
  18. #43
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Alright, placed orders. Wallet is gasping a bit, flopping like a fish out of water.
    Nate J.
  19. #44
    JimLev's Avatar
    Sundance Mesa, NM
    Guess you'll be eating P&J sandwiches for the next few weeks.
    I think Philly mentioned a while back about plastigauge. I've used it 3-4 times and found it to be accurate.
  20. #45
    Mar 2017
    Lynchburg, VA
    2001 540i
    Some people blow all their extra money on replacing a broken refrigerator or air conditioner or installing gutter guards. You are blowing yours in a very good way!
    2001 Salvage Title 540i
    My build thread: https://www.bimmerforums.com/forum/s...toive-decision
  21. #46
    Mar 2012
    Lansdale, Pa
    Looking forward to your pile of shiny new parts! Going to be like new when your done!
  22. #47
    JimLev's Avatar
    Sundance Mesa, NM
    Nate, we want pics.....almost no one posts the guts of the S62.
  23. #48
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    +1. I do love a PB&J on soft white bread. Not too bad.
    Yeah, the plasti-gauge is how this whole thing started to begin with.
    Nate J.
  24. #49
    So, it's $5k for the "M" tax.... ?
    Wow... lol.
    Makes you miss the 530i I bet .
    Jim is right... Need Pictures !
  25. #50
    JimLev's Avatar
    Sundance Mesa, NM
    The more engine porn the better, especially S62 porn.
  1. My Successful S62 Engine Rebuild and Intro
    By JackM in forum 1996 - 2003 (E39)
    Last Post: 02-27-2019, 06:29 PM
  2. M10 Engine Rebuild Threads
    By tatiananoel in forum 1975 - 1983 (E21)
    Last Post: 02-19-2013, 09:23 AM
  3. Forged S62 engine rebuild!
    By razahyde in forum Forced Induction
    Last Post: 12-08-2012, 04:23 PM
  4. WTB: S62 engine/tranny
    By MrWingnut10mm in forum BMW Parts Wanted
    Last Post: 03-18-2004, 12:06 AM
  5. Bay Area bimmer shop that can do engine refresh?
    By maomaoLTW in forum 1992 - 1999 M3 (E36)
    Last Post: 07-28-2002, 10:49 PM
