Results 1 to 5 of 5
    Jun 2018
    Gatineau
    BMW X5 2E53
    Major issue with brakes.
    It all started when the rear bushings had to be replaced because of alignment issues. They had to replace both brake lines due to major rust on the lines. This is where it all started.
    NO F....g Brakes. or so little.
    This E53 was braking okay before.
    They followed the newTSI.info procedure as to HOW TO BLEED BRAKES AFTER LINES REPLACEMENT.
    Actuated the ABS pump on auto-bleed mode AND after, pump the pedal 5 times on each wheels
    NO SUCCESS.
    They replaced the master cylinder with a new ont NO CHANGE.
    While they were at it, they noticed that the master was leaking (minimal ) air so they replaced it. NO CHANGE
    While bleeding the brakes one of the front line busted so they replaced both sides NO CHANGE
    While replacing the lines AND bleeding, one of the metal lines under busted so they replaced BOTH lines. STILL NO CHANGE.
    every times they replaced something, they went thru the procedure without and improvement SO SAD.
    Now I do not know what else to do.
    HELP.
    Jun 2018
    Gatineau
    BMW X5 2E53
    Update.............
    They discovered that they HAVE to use DOT 4 LV instead of the original DOT 4.
    Went through the whole procedure more than 5 times, ( ABS Autobleed and pump 5 times of brake pedal ) but no change the brake pedal is spongy, and you don't get the B'MW Braking power that it used to do.
    HELP
    Jun 2018
    Gatineau
    BMW X5 2E53
    Bump
    Northwest Ohio
    2001 750iL
    Yeah. I'm in the same spot after replacing my rear lines. But I didn't see the procedure for bleeding (ABS Autobleed + pump 5 times). Was looking for that info in ISTA but to no avail. I'll have to dig further.
    2005 X5 4.8is (DD winter) * 2001 750iL (DD summer) * 2001 Ford Excursion 7.3 L <> 2005 X5 3.0 * 2003 X5 4.4i * 2009 X3 3.0 * 2009 X5 3.0 * 2007 Toyota Avalon Limited
    May 2009
    Greenville, SC USA
    e39 M5 e39 540i6 e83 e53
    Its in ISTA, just look for rear caliper replacement in technical documents. You should use DOT4 low viscosity and bleed starting with RR, LR, RF, LF calipers.
  1. Anyone ever had a clutch stop cause a major issue?
    By Chapel in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-05-2005, 05:17 PM
  2. Is this a major issue (tread crack)
    By skidder in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-16-2005, 11:13 AM
  3. Car is having some MAJOR issues
    By '94 325is in forum 1991 - 1999 (E36)
    Last Post: 12-14-2004, 11:21 AM
  4. Wheel help major issue
    By sbkrider in forum 1991 - 1999 (E36)
    Last Post: 09-17-2004, 07:57 PM
  5. New issue with brakes
    By BetaTested in forum 1975 - 1983 (E21)
    Last Post: 11-26-2003, 03:42 AM
