Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 56
Thread: New build - E36 with an N54 Twin Turbo!
  1. #26
    Vestal, NY
    E30S62, E21S54, E31S85
    Quote Originally Posted by FiberFast View Post
    Attachment 650828
    Handle Bar, a torsion bar for the diff/swaybar reinforcement. Bolts into boxed in tabs at the swaybar bushing mounts.
    Sounds like a fun project to tool around with! Good idea I値l give it some thought!
    Sent from my iPhone using Tapatalk Pro
    Frank Macaluso - BMW Drivetrain Transplanter
    Frank Macaluso
    http://www.garageaholic.build
    BMW Engine Swaps
    Current Swap 2016 LT1/6 into E24 6er
    607-953-9587
    Contact@garageaholic.build
  2. #27
    Jun 2016
    California
    E36 325is
    Quote Originally Posted by Garageaholic View Post
    For sure man, I had intended to thread the ends of the torsion bar so you could pre or post tension it. I just drilled a hole though the bracket reinforcement tube and dropped a lich pin through for a prototye. I want thicker boxes anyway and I am changing the way it bolts to the diff, I plan on keeping those tabs but I want to make a tool kit that allows you to tap those cast iron holes. Since you are using a different differential you will need to devise your own diff mount/bushing, but the concept is the same for any rwd McPherson independant setup.
  3. #28
    Vestal, NY
    Time to weld the stainless steel exhaust!
    What's up everyone! Another update this evening and that is EXHAUST!! So to discuss a little bit of what I did and how I did it. I wanted to keep the exhaust as stock as possible, but with a bit of a kick, so to be honest nobody knows what an exhaust will truly sound like until it's finalized and installed, but I think this will sound reasonably tame, for now.
    First of all, the turbos themselves do a good amount of muffling before it even gets to the Cats. And yes, I'm keeping the catalytic converters. I'm trying to be environmentally responsible here, but more important than that I want to pass inspection, so I'll have probably a few videos on that in the future. That is my most commonly asked question for my engine swaps is emissions and inspection.
    So from the turbos, they come down the modified downpipes through the cats. Keeping both O2 sensors, they then go through the 2.5" V band clamps. These are sometimes a pain to line up, even with the alignment lip built into the assembly. Especially given the welding warpage and other factors like that. Just something to keep in mind.
    Then it goes to the X-pipe in a weird pre-cross over. I know it looks funky, but it's functional, and actually more efficient than doing it the other way around. Easily avoids any interference to the passenger footwell.
    From the X-pipe, it gets simpler. It goes straight through to the E36 M3 stock muffler, which is also 2.5", so no restrictions there.
    Like I said, this will probably be relatively quiet. If we want it a bit sportier, we can always put a magnaflow glass packed dual in/out muffler.
    So I have 2 hangers. One under the transmission bracket as pictured, and then stock hangers at the muffler. This is designed as one big exhaust piece, as designed. I thought about incorporating another set of V-bands for say, any rear suspension or diff work, but the work involved with removing the back half of such a suspension is just as much work as removing the suspension from the downpipe V bands.
    Now on to the pictures and the Youtube video if you care to watch!!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  4. #29
    Vestal, NY
    Oil Cooler Install
    Now it's time for the oil Cooler Install. This was not difficult. Just again connecting A to B. I used the existing E92 N54 Oil Cooler Installation location. So all parts involved are stock parts, except the mounting to the body. That's all welded. Pretty simple. I didn't take any pictures, just a video. So watch if you'd like!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  5. #30
    Vestal, NY
    Now it's time to install the coolant reservoir, tank, heater hose lines, and bleed line to the radiator, not to mention the actual radiator hoses themselves! The radiator was positioned perfectly to allow the upper and lower radiator hoses to be installed without obstruction. The heater hoses required the most amount of fab work, but even still it wasn't that bad.
    The bleed line was also pretty easy. Being a 1/4" hose for routing, it was generally pretty easily manipulated.
    Now on to the theory. This is how the coolant routes in the E36 with the N54 hoses.
    Coolant Reservoir Installed with new welded mounts as well as the lower third mount (cannot see below reservoir)
    The heater hose (hard line from E92) also mounted pretty easy, but I needed to cut it short and allow a 3/4" heater hose to then install on it so it can go into the heater valve on the firewall. I installed this hard line to the steering rack bolts. Just needed to make a few extra relocating brackets to accurately position it.
    And just for fun, 3 Swapped 3 series!
    E30 S62,
    E21 S54
    And the work in progress E36 N54!
    Now on to the video of progress!!
    Thank you guys for reading - Hope you are learning something!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  6. #31
    Vestal, NY
    Brake Booster Vacuum, Engine Ground, and Heater Hose
    Ok, so more progress today. Today we worked on the Brake Booster Vacuum Line and the Engine Ground, but also cleaned up a little the heater hose return from the firewall down through and across to the pump.
    Not much to say on the booster vacuum line. Pretty self-explanatory and relatively easy hookup. Just needed to use, yes, another Oetiker clamp! Gotta love those. I did something similar for the heater hose, so make the hose a bit more single-pieceish.
    Engine ground was pretty easy too. Just make a large gauge wire that goes from the engine block to the body frame. I don’t think I picked an ideal spot for the engine frame unfortunately. I didn’t have the room I wanted to drill into the frame, so when we take the motor out, I might relocate it. The video tells all, here. Again – pretty self explanatory.
    As a courtesy, I wanted to send you guys a pictogram of the power steering lines and how I hooked it up. Hope this helps.
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  7. #32
    Vestal, NY
    Ok guys, so today we tackle the fuel system! I've decided to take the existing fuel system completely out and replace it with a known newer E46 M3 version.
    So this is the old assembly from the E36 M3.
    Here is the new E46 M3 Filter and Regulator. You can simply not use the regulator vacuum line. The regulator regulates the incoming fuel pressure to 5 bar, which should be more than enough for the N54.
    And I labeled each of the 5 tubes (Pipes) going from front of the car to the rear of the car. Includes the 2 brake lines.
    Now on to the video! It is pretty comprehensive in terms of what's entailed for the installation.
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  8. #33
    Vestal, NY
    Air Conditioning Lines!
    So now it's time to work the Air Conditioning Lines. That's right, this track E36 will have air conditioning. And honestly, modifying the lines to adapt to the E36 was not as difficult as one might think. The video below explains it pretty well, but overall you just want to match A to B, just like with the power steering lines, and the Drivetrain Positioning.
    Some pictures of the final installation after welding them together.
    And here is the air conditioning schematic. As you can see there is no explicit air dryer. That's because on the E9X, the dryer is built into the condenser. I explain it on the video, but it was a godsend because it saved a lot of space in the engine bay not having to mount a big bulbous air dryer! Hope you enjoy and learn something!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  9. #34
    Vestal, NY
    N54 Wastegate Rattle and Reassembly
    Update for all ya'll guys! So I removed the engine - Took 25 minutes. Much easier to remove them after modifying the exhaust headers to clear the frame rail. Once I removed it, it was time for factory fixes. Up until this point, I've done just a handful of fixes.
    Clutch, Release Fork, throwout bearing
    Turbo Wastegate Rattle fix and rebuild kit.
    That right there necessitated 3 videos, in order to cover it in the level of detail I needed. I understand there are so many Turbo wastegate rattle videos out there, but another one couldn't hurt, and there was some detail in previous videos (tips/tricks learned) that were not covered that I wanted to share with people, so I did have some info to share, which was nice.
    So let's remove the engine and inspect/replace the clutch:
    Once that was done, it was time to remove the turbos for bench reassembly. The 2 hardest parts of the wastegate rattle fix was:
    1. Drilling out the pin with a HARD cobalt or titanium coated drill bit
    2. Even harder was removing the old bushing.
    To remove the bushing, I needed Heat, a grinder, and finally a punch with a 5# hammer to finally push it through. But once that was done, the rest of the reassembly was key. The one big thing I learned from doing both these turbos is to mark the location of the existing wastegate lever arm BEFORE you grind it off and remove it. Very important or everything else will be off!
    The first video of removing the turbo, reworking is here:
    And the second video of reassembly with all new O-Rings, seals, is here:
    Finally, for those of you who want pictures, here are a few of the final shots reinstalled for your viewing pleasure!
    Next up is final engine stock fixes and engine bay prep because you know what? Alpineweiss #300 paint has been acquired!!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  10. #35
    Jun 2016
    California
    E36 325is
    Looking good man, starting on some sanding on the exterior of my wip. Cant wait to see how your paint comes out.
    Also scoping those OE exhaust manifold nuts, anyone run these on an M50/M52 with longer studs? Those look tits.
  11. #36
    Vestal, NY
    Ok, some more progress on the E36 and the N54 Engine!
    On the N54, we completed with installation of the coolant pump assembly, engine serpentine belt, tensioner, idler pulleys. I've heard about serpentine belts shredding and causing major problems by wrapping around the crank and that's no good. This is typically caused by a leaky valve cover gasket and/or oil filter housing gasket. Both of which will be replaced at a later date.
    You can see all of the oil leaks here. Really bad. Happening for a while now. So I plan to powerwash the engine safely and replace all those gaskets.
    I replaced the transmission output shaft with one that will work for this swap. It's from an E46 M3. Correct 96mm size to mate up to the existing E36 S52 auto transmission. Had the right spline count, size, and output seal size too. It was nearly perfect!
    I fit the charge air pipe in. The video below shows why I was nervous about installing this, but I think I have it all figured out and have afforded myself the room I need to clear the frame rail.
    I got the new clutch installed. I didn't have a clutch alignment tool, so I made my own and it worked out pretty darn well! I didn't even have a lathe to make it perfect. Just got lucky I guess.
    I got the oil pan reinstalled with a new gasket!
    Installed a new guibo, some new shifter parts and I'm good to go!
    Take a look at the video below hope you like it!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  12. #37
    Vestal, NY
    Now it's time to prepare the engine bay for paint. As a shadetree mechanic, I did my best to shave the bay. The front left wheelwell housing had damage from what looks to be a previous accident. Appears to be something that can be rectified, and I did my best to use filler and smooth out the imperfections to be less imperfect!
    First, we cut out the frame rail to make more room for the charge air intake tube for the rear turbo. Couple pictures for you to mull over. I know the welds need to be improved. I'm learning how to better weld sheet metal.
    Top View
    Here's a quick video of the work I performed up to date. Below is more work for engine bay prep!
    Then I powerwashed the engine bay. Some Before/After are pretty dramatic.
    The above pic needed a lot of work, in particular the bondo that was revealed.
    Powerwashing the engine.
    Next up is Paint - Let's get this bay prepped and painted! Standby for more progress tomorrow!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  13. #38
    Vestal, NY
    More Progress!!! Let's see some paint huh!?
    So I had to paint 4 Items:
    Front bumper
    Grill Support
    Core Support
    Engine Bay
    Most of the prep was pretty easy. I wasn't going for perfect, especially since the car is far from perfect, but more because I'm still learning!
    First, I performed some body fill on the parts:
    Put some seam seal on the welds:
    Then I Primed them:
    Then I painted them. Base/Clear 2 stage paint: I didn't do any color sanding, but that can be done later after the clear coat hardens a bit more.
    Started Assembly:
    I had an issue with the grill. It cracked, so I used come Q-Bond, which is a powder type material and when you put Krazy Glue on it, it instantly hardens. AWESOME tool for anyone who needs to fix a plastic piece or part that broke. Very useful.
    So I primed and painted the grill and installed it in the grill support.
    This video is kinda long, but it has some good info that you might like!
    Thanks for watching guys!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  14. #39
    Vestal, NY
    Now that we got the paint on, time for final assembly! This was eventually broken out into a few videos. I did this because of the sheer work and level of detail I wanted to cover. Now, I broke it out as follows:
    Prepping for Final Assembly:
    Rhino Liner Install on below the frame rails. I removed all of the masking from the engine bay. Reassembled the M3 bumper. I fixed the grill, painted it, and assembled it into the grill assembly.
    i also replaced the valve cover gasket and spark plugs. This was right before I decided to clean the N54 Intake Valves, which became completely gunked up due to the direct injection of the fuel injectors. Common issue on the N54 engines, or any turbo application with direct injection.
    I also started the oil filter gasket. I replaced all of the gaskets in the oil filter housing and you can see that through the next video(s) that I made. So this will help greatly reduce if not eliminate any more oil leakage.
    No real pictures of the aforementioned, but the video is a pretty good watch.
    Then I installed the clutch line, from the master cylinder to the slave cylinder. Did some dynamat installation for sound deadening, DME install, and engine install. Let's see how this puppy looks in the engine!
    Here's the video if you wanted to watch it! A lot more details here than what you see in the pics below. Hope you find both interesting.
    Now on to the pictures:
    Installed the heater hoses, tightened them up because replacing/tightening them later will be very difficult!
    A bit of art for the Battery B+ Terminal! Get ready to wire to it later!!
    DME Installation in the stock E36 location. Much larger DME than the S52 that was in there before, so I needed to adapt it to fit. Turned out quite nice and pretty robust too!
    Dynamat Installation Completed. Ready for Engine Install!
    As promised, I beefed up the Transmission Mount. There were some comments about that, so here you go!
    And Finally, the engine sits in the engine bay on its own weight, in it's stock location under the weight of the Poly Mounts!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  15. #40
    Vestal, NY
    More updates to share!
    Today was the dredded Intake Valve Cleaning! Due to the direct injection of fuel into the combustion chamber, there are emmissions standards that dictate that exhaust recirculation back into the intake be done to burn up any unburned gas, this creates carbon buildup on the intake valves, whereas in a port injection car (non turbo most frequently), the fuel injected keeps the intake valves clean, so no issues there.
    Regardless, we tried a number of techniques, physical scraping, Intake Valve Chemical cleaner, and finally we tried to soda blast. Didn't come out EXACTLY how we liked, but it wasn't too bad. Much better than it was!
    Before Shot:
    After Shot - Again - not ideal, but better.
    This was even after the soda blasting. Next time, walnut shells and a vacuum adapter!!
    This one here:
    https://www.ebay.com/itm/Walnut-Blas...8AAOSwvMFa3737
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  16. #41
    Vestal, NY
    Some more updates! Final Assembly time has come. So exciting to see everything start to come together on these types of swaps. Today we work on all underside type assembly work. This includes the Shifter with Boot, Driveshaft, Reverse Switch Installation, Clutch Line, Steering column, heater hoses.
    But that's not fun. Final installation pictures are fun. So enjoy! Remember I still haven't fired this thing up yet.
    Assembled the front bumper to see how the intercooler fits. Fits pretty good!!
    And finally, a couple videos of my detailed progress if you wanted to watch!
    In this video I cover a bit more on the engine side, including the infamous oil cooler gasket leaks. Show you how to fix that as well. Pretty straightforward.
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  17. #42
    Vestal, NY
    Wiring up the PWM Controlled Electric Fan
    Today, I wired up the PWM Electric Fan. So First, to get my brain wrapped around all of the connectors, I clamped them together between 2 pieces of Delrin. Just to identify all of the I/O I was dealing with:
    The fan on this application from the 335i X-Drive is a 600W fan version (Not the 400W version). Regardless, there are 3 populated pins on the main connector. + (RT/SW), - (BR), and PWM Signal (SW/BL) Pin 8 on X60001.
    The video below is 2 fold:
    The first part shows you how I wired it physically. The second half shows how to read the wiring diagrams on WDS and how I arrived at the conclusion for pinouts and relay wiring.
    Hope you enjoy and learn!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  18. #43
    Vestal, NY
    First start!!!
    This is probably my most exciting post! We finally got it started! It took so many tries, updates, retries and failed attempts to finally get it started.
    Generally speaking, I thought originally that I could start with just the CAS3 unit, Key/holder, Start Button and be done with it. But i've been told many conflicting theories, so it naturally made me quite nervous. Regardless, I pushed ahead and did the best I could with the wiring diagrams and advice from a few people I received on the subject. Regardless of all of this, I plan to have the DME flashed to remove EWS and get it tuned. This will be done by Kassel Performance in Pennsylvania. (https://www.kasselperformance.com/) They have been very informative of their products, technology, and even offered to help me with the wiring to get it started on CAS.
    Overall, I wanted to see if I can just get it wired on CAS. Because I have an S85 waiting for my E31 and need to know for sure if all I need is the matching CAS/KEY/DME set. This post is set out to confirm or deny that!!
    Here are a few pictures of the wiring. Yes, it's not organized, but due to wire lengths, splices, location of modules, it made it quite messy. Nevertheless, I know it's not very informative (yet), but more detailed wiring info is coming along soon!
    Here is a shot of the A4010 Junction Box with the Main Relay there on the right.
    This first video is me trying to get it started on CAS3, then failing, so I went back to the donor car to pull the A4010 unit with the A4010a body control module.
    Then in my second half of the effort, I wanted to see if you really need to have all that wiring shit there, like the junction box. So I started to step-by-step strip the wiring away from the junction box, and eventually eliminated it. Spoiler alert, it started only on CAS! Yes there will be fault codes, but there's ways around that with CAN Emulators. Again, I plan to have it flashed anyway, so I will work on an emulator another time, perhaps for my S85 E31.
    Here's a picture of just the CAS unit hooked to the engine. I deduced that the reason it didn't work originally is because there is this one EWS wire, not explicitly labeled on any of the N54 wiring schematics. It is a GN/WS wire that connects the CAS to the DME. Again, not in the schematics for the CAS, but it is there for the X60001 connector on the DME. So I took a chance and deduced that the wire, being the same color, gauge has to have something to do with the EWS. It was called "_ZRS" on the X60001 - Pin 7.
    And here is a video of how I slimmed down the wiring to the basics. I hope you enjoy and learn something!
    And finally, I wanted to let you guys know that I do plan to issue a detailed integrators guide for the N54, specifically geared toward the E36. It will have detailed wiring, pinouts, part numbers, wire lengths, Exhaust Setup, Drivetrain alignment specs, cooling, A/C, P/S integration and much more. I hope you will find it useful when it comes out in July!
    Thanks again for watching!
    Frank
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  19. #44
    Vestal, NY
    More updates!! Mostly good news, but still some setbacks
    First, we reassembled the interior. Not much there, but we did put in a pretty cool steering wheel, meant for the E36. Just need to modify the slip ring to fit the different hub on the aluminum casting in the wheel. More on that later.
    Did a little Vacuuming
    Have some seat twist in the drivers side. Presumably completely messed up. Looks like some shoddy welding, that's for sure.
    Got the reverse lights working completely!
    And a quick video on the interior assembly. Nothing super exciting!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  20. #45
    Vestal, NY
    Ok, Ok. I know that one was just a fluff post. Nothing really useful there. But here I have more to contribute. First TEST DRIVE!
    part of that was bleeding the clutch. Including the slave and master cylinders. This was particularly frustrating. It took me 15-20 iterations to finally get it bled. I used a vacuum bleeder to such the fluid out of the bleed screw from the slave cylinder, kept pressure on the pedal while sucking, and continually added fluid to the reservoir so it didn't accidentally suck air in from above.
    After I got just a bit of pedal pressure, I pushed the pedal down, left it there since it was spring loaded, and then opened the bleed port. Then CLOSED the bleed port, and pushed the pedal 20-30 times. Then pushed the pedal down easy until it hits its resistance point. Lather, rinse, repeat.
    I installed the oil cooler tubing for cooling. Pretty straightforward. Used Large Vacuum hose and just bent it into place.
    Tied on the grate for the front bumper. Something I DEFINITELY should have done before installing the bumper, but it was still possible. Filled up with coolant, cycled the power steering and off I went.
    The engine was in Limp Mode for sure. No Turbo Spool, presumably due to all of the faults resident in the loss of comm between the DME and everything else.
    After getting the CAS working (still DT's exist though), I was super excited.
    We did some more final FINAL assembly. Some pics below, but again nothing special.
    Now it's time to complete the final assembly while I concurrently work with Kassel Performance for their much welcomed sponsorship to help pave the way and flash this DME for all to enjoy in the future!
    Car felt great though. Very tight, very comfortable. Can't wait to finish this thing! Thanks again all for watching and following
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  21. #46
    Dec 2014
    Des Moines, IA
    '97 M3/4/5.0
    Congrats on the first drive! Always a huge milestone!
  22. #47
    Vestal, NY
    Quote Originally Posted by Laminar View Post
    Thanks! Those 2 milestones: first start and first drive are always amazing
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  23. #48
    Vestal, NY
    Some more updates - I have run into some setbacks working on eliminating CAS, and the DME is surely in Limp Mode. I can tell because the turbos whine up, but the throttle body is not opening up nearly enough to allow positive pressure into the intake manifold therby allowing air to bypass into the blowoff valves and close them up.
    Quick video of updates here:
    Yup, I have Pressure! Blew a cheap clamp - Just replaced that quick
    The blowoff valves open up back into the intake once the vacuum reaches 7 in-hg. So during normal driving, the intake has constant vacuum (up to 30 in-hg) and the blow off valves are open allowing all turbo to flow back into the intake. Interesting way it works! So when you have boost pressure, the intake manifold starts building postitive pressure, thereby closing the blowoff valves allowing all of the air to go into the intake. Once you let off the gas, the vacuum in the intake opens the BOV (blow off valves) and relieves any residual pressure.
    Working on the Air conditioning system. I need ed to scavenge an E36 pressure sensor for the high side to protect the compressor. So needed to cut one off the stock E36 line and weld it to the custom high pressure line I made.
    Working on some wiring and flashing with Kassel, They have managed to remote flash the DME for me, so we have been running a few permutations of that with no successful elimination of CAS.....for now. We WILL get this.
    Concurrently, I am working on an alternate solution option of a CAN Emulator to emulate all of the CAN signals that prevents the N54 from being in Limp Mode. More info on that later!
    So this is the car as it sits today!
    Latest video can be found here, hope you enjoy!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  24. #49
    Vestal, NY
    Some more updates this week. I worked strictly on the Air Conditioning. Tried, but failed to get it running. I replaced the Expansion Valve, rewelded some tubing, replaced O-Rings, evacuated, and filled. It seems like I need a new compressor, so I ordered a new (used) one and hope that may fix why my the pressure on the high and low side is about the same, regardless of whether the compressor is kicked on or not. So having said that, not many pics, but I do have an updated video of my trials and tribulations.
    Holding Vacuum on both hi and lo sides
    Some new O-Rings on my custom Aluminum tubings
    Reset the airbag codes while I'm at it!
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  25. #50
    Vestal, NY
    Do you think I forgot about you!!!
    More updates guys! Yes, progress is slowing down, but that's for good reason. 90% of the swap is easy - Installation, mounting, welding, placement, peripherals. Sure, that isn't that hard. Heck, people do demo of the donor car in a day and think they're half way done with the project.
    The real kicker is the fine tune adjustments to ensure that the swap ACTUALLY WORKS. That means, engine codes, passing emissions, removing rattles, shakes, vibrations, idiot lights, and getting everything to "play" together effectively. That's what REALLY takes the time.
    So without any further adue (Spelling?), I provide updated status. I was wiring up the X20 port for the basic signals required for the chassis to interact with the engine. This includes
    Fuel Pump
    Switched Power
    Start Wire
    Oil Pressure
    Coolant Temp wires
    A/C Compressor Signal
    So I cleaned things up a bit
    Then I started the engine so many times I lost count if I were to count by hundreds. I am now going through all of the error codes and after the car runs, I find that the engine gets into limp mode. Remember that for now, I have a CAS/DME setup, meaning that the DME requires CAS to start. Wiring between the 2 are shown below for the E92 335i (2010).
    First Power: Pins 1, 8, 19, 21, 34Second, Grounds: Pins 12, 25Third, the 3 signal pins to X60001 -Pin 30 (WS) goes to X60001 Pin 15 (PA_BUS)-Pin 28 (SW/GN) goes to X60001 Pin 2 (S_START)-Pin 7 (GN/WS) goes to X60001 22 (15_ZRS)Starter: Pin 22 (thick)
    But I still get error codes. Tons of comm codes. But none of them really cause an issue with either OBD or engine performance. There is one however that causes limp mode, and that is a power class mismatch, code 2FA4. Here are the error codes I get after running the engine for at least 60 seconds.
    i realized that the car runs flawlessly for the first 45-60 seconds, until this 2FA4 code comes up. This video below sums up my experience and how the car works after I key-cycle.
    What I discovered after idling the engine was that after 60 seconds that 2FA4 code comes up, If I reset the code in real time, the car gets out of limp mode until the code comes back, predictably 60 seconds later. So me and my buddy decided to partner up and invent an arduino mega controlled CANShield board that automatically sends out the 6F1 PT_CAN ArbID that resets the engine DTC's every aaaaaaah, 20 seconds or so? This effectively prevents the car from ever going into limp mode.
    Rest assured that this is not the final solution. but rather a band aid for me to drive the car and work out any other drivability issues.
    The final solution will be Kassel Performance flashed DME. They have been working diligently with us to come up with a solution for MSD81 and remove EWS4 and CAS3 from the system. This has proven to be more complicated and more of a challenge than originally anticipated.
    So here is the automatic code resetting arduino tool:
    It basically taps into the PT_CAN bus. There is a terminating 120 ohm resistor already at the OBD Port and at the EKPS, so you may put anything else into the PT_CAN 500kbps line and we decided to inject into the backbone with this resetter tool. We have a discrete ground signal hooked up to a rocker switch so that we can turn off the auto code resetting function at any time if we suspect a real code and problem with the engine.
    So I moved on to get coolant temp in the dash and decided to replace the existing 2 wire sensor and use the 4 wire coolant temp sensor. 2 wires go to the DME as originally intended and 2 wires go to the cluster.
    Kassel Performance makes a harness that adapts the new 4 wire switch and makes it plug and play. Very convenient, But my setup was slightly different because I snaked the 2 wires in the engine harness (GE and GN) for cluster sense.
    Finally, I moved on to the muffler. Removed the stock E36 M3 muffler and tried replacing with straight pipes, but it was too loud, so we decided to go with 2.5" single in/out resonators, 2x of them. Worked out amazingly as you can hopefully watch in the latest video.
    Installed the dual resonators in place of the big heavy muffler:
    Dual 3" Tips to be trimmed and painted black:
    And finally finally, I got the engine bay sorted out and completed the air intake scheme. hope you like.
    Hey guys, if you were ever interested, I am also nearing the end of my E30 S62 "life after people" restoration series. It's a 10 video series of how I resurrected my own build from years back and got it back to current standard by making some standard and not-so standard replacements on the car! Thanks!
    https://www.youtube.com/playlist?lis...TzU2no8EvXGz8x
    Frank Macaluso
    BMW Engine Swaps
    607-953-9587
  1. E39 530i upgrade from M54 to N54 twin turbo, any one did it?
    By FLASHBACK 530i in forum 1996 - 2003 (E39)
    Last Post: 06-05-2021, 12:48 AM
  2. E36 M3 1JZ-GTE Twin Turbo Build! Purists Beware
    By Reilly1JZ in forum Engine Conversions
    Last Post: 07-05-2015, 12:12 PM
  3. N54 twin turbo fuel pump problem
    By bmwgolfguy5 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-15-2011, 09:51 AM
  4. E9x N54 Twin Turbo engine. 7000 miles.
    By ///mfizzle in forum Engines, Performance Parts & Software
    Last Post: 08-24-2010, 08:20 PM
  5. New Build e36 M3 GTS3/CM Racecar
    By mgmann in forum Race Cars & Track Parts
    Last Post: 12-02-2009, 10:23 PM
