Results 1 to 7 of 7
Thread: Touring Rear Hatch Hinges Sticking?
    Chicago area
    too many....
    I tried Googling this, and nothing useful came up. The rear hatch (not the window) on my 2001 525iT feels like it is sticking or binding on the passenger side in the hinge/shock assembly. Before I go digging into it, has anybody else run into a similar condition and have some advice?
    Thanks!
    Vince
    Jan 2016
    Ca
    2001 525it
    Did you lube it yet
    Chicago area
    too many....
    I did not lube it yet as it didn't feel like a typical stuck something, rather more like a spring slipped out of place and is sort of jammed. Google didn't turn up anything. Now that I'm at home, I'll look at it on realoem and see what it looks like.
    Vince
    Jan 2016
    Ca
    2001 525it
    There is no spring ther are two gas lifts per side on supports the hatch the other supports the glass remove the plastic covers and you will see them but I would try the lube because how easy is that. Does the hatch stay up?
    Jun 2013
    Lancashire - UK
    2002 BMW E39 530i (UK)
    As above
    Give it a good rinse out with a penetrating fluid (wd40) or similar, let that dry off and then respray with the likes of lithium grease etc
    This is what I’d do personally
    My car: 2002 E39 540i Sport - Japanese import - the new project!
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    Quote Originally Posted by jclausen View Post
    Strut with spring.
    Might be best to replace, as they are probably bad anyway.
    Plastic shield would prevent lube from getting where it needs to go.29364.jpg
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    I've had a Sticky hinge turn into a hinge failure. Just posted to another thread, and saw this. The hinges are well hidden, and in hte rust belt, they take a beating. I have a 99 ( came from Boston in 2012 with 197K ), now at 212k. The hinges were on the verge of failing from day one. It felt 'weird'. When it breaks, the hydraulic strut takes over, and pushes the door out. I got 2 southern hinges. the pin rusts out, not the casting. hope this helps.
  1. WTB: E39 Touring passenger side rear hatch hinge
    By ZOP in forum E39 Touring / Wagon
    Last Post: 10-05-2016, 12:28 PM
  2. E34 WTB: Touring rear hatch spoiler
    By Wuffer in forum BMW Parts Wanted
    Last Post: 11-25-2009, 12:40 AM
  3. Touring rear hatch hell, part 1
    By flipwils11 in forum 1988 - 1996 (E34)
    Last Post: 08-06-2009, 11:12 AM
  4. Touring Rear Hatch Issues
    By AquilaBMW in forum 1988 - 1996 (E34)
    Last Post: 06-17-2009, 10:23 PM
  5. Touring Rear Hatch Glass Adjustment
    By IamCatman in forum 1988 - 1996 (E34)
    Last Post: 05-12-2007, 02:05 AM
