Today while driving had a P130a code.
When i pressed the guys, was not as responsive. Google has very little on this code.
Any ideas ?
Looks like severe misfiring.
http://wiki.ross-tech.com/wiki/index.php/P130A/04874
You guys recommend I change the spark plugs ? Can only has 56000 KM on it and driven 3 months a year.
Seems like a good first step
Okay will pick up some stock Spark plugs from my local BMW dealership unless you guys recommend something different.
If the misfire is bad enough the cylinder shuts down it's probably more than the plug.
Possible Ignition Coils ?
Misfires are typically. Coil, plugs, wires. If easy enough to change all at once that would be the recommendation
Thanks all for the info, I cleaned them and everything working well. Great help on this site....
