Results 1 to 4 of 4
Thread: New to ista question.
    Sep 2016
    NH
    98 m3, 00 525i
    Been getting a random pop noise that sounds like a cylinder misfire. I decided to check ista to see if it had a misfire live data stream.
    I found the rough idle data stream.
    Appears that cylinder 5 is way different from the other cylinders.
    I swapped spark plugs, and coils to seee if the difference in numbers move from cylinder to cylinder. After doing so, I ran the stream. And nothing changed.
    What is the tough idle actually giving us?
    This has to be an injector issue/ bad compression on cylinder 5?
    Here’s a pic
    upload images
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    A misfire can be caused by a myriad of things:
    - bad spark plug
    - bad coil
    - bad connection at the coil
    - bad MOSFET (an electronic part that fires that coil)
    - low compression
    - bad fuel injector
    - leaking fuel injector
    My first step would be to perform a compression check on all cylinders. Any value that is off by 10% or more is a concern.
    Sep 2016
    NH
    98 m3, 00 525i
    Quote Originally Posted by MarcoZandrini View Post
    - bad spark plug
    - bad coil
    - low compression
    - bad fuel injector
    Are the numbers normal in the picture ? I have already swapped the plugs and coils. (I highly doubt compression is an issue) But I guess that is the first step.
    I’m not getting any codes for misfires. And I haven’t checked misfire counters yet.
    Just to confirm:
    Compression test
    It can be done multiple ways?
    1. Adjusting valvetronic motor at proper angle to open the throttle I assume?
    2. Unplugging injector rail connector.
    3. Turn over the engine a few times to get the gas out.
    4. Remove spark plug + proceed with installing compression tool. And carry out a compression test.
    -moving on to the next cylinder.
    5. Continue on ista menu. Re adjust the valvetronic motor again? And test the cylinder.
    Is this the proper way of doing it?
    Mar 2019
    San Francisco CA
    97’ Z3 M44, 74’ 2002 M10
    Before investing in a comp tester, unless you’ve already got one, I’d suggest remove coil and spark plug from cylinder five and exchanging them with other cylinders.
    ex. take coil out of five and put it in four, remove spark plug from five and put it in three. check again to see if the misfire jumps with either one..
    if it jumps with spark plug then replace spark plugs. If it jumps with coil replace coils. If it doesn’t proceed with comp test.
  1. New E28 Member questiones
    By E28TOM in forum 1982 - 1988 (E28)
    Last Post: 12-12-2002, 10:51 AM
  2. Sorry, new guy dumb questions
    By Dieter03 M3 in forum 2001 - 2006 M3 (E46)
    Last Post: 09-30-2002, 09:14 PM
  3. new car, key question
    By ccolt in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-23-2002, 12:06 AM
  4. New 318i -- Some Question
    By Rollen318i in forum 1983 - 1991 (E30)
    Last Post: 08-20-2002, 01:09 AM
  5. new 5 series questions
    By Ray z in forum 1996 - 2003 (E39)
    Last Post: 07-08-2001, 11:28 AM
