I was taking out the blower fan regulator so I could find the part I need and replace it. I took out the glove box, air bag, etc. got to the regulator took it out, copied down the numbers and put everything back the way it was. When I reconnected the battery...nothing! The only thing happening is the indicator light for PARK on the shifter flickers and the two lights by the convertible top buttons flicker. Any ideas?
Thanks,
Boyd
I believe the fuse box is located behind the glove box. Since you were in the glove box area working, I'd look over everything for any wire's or plugs which may have poped off.
2nd the above either some thing is not connected right or a plug is not seated all the way or some main fuse blew
