Will M50 and M54 Wiseco pistons and Carrillo rods interchange?
On my latest turbo build a M54 2.5 i need forged internals my question is i have a set of new wiseco 8.5 pistons and Carrillo Pro 135mm rods for my spare M50 2.5 that have never been used so i would like to use in the M54 block but part numbers are different .With both engines having the same bore and stroke does anyone know why this wont work. Only things i can think of is deck height on blocks may not be the same, Combustion chamber size and or valve size is maybe different on the M50 and M54 heads? any ideas.. Thanks
2001 Z3M S52 OBX T4 Top Mount, GTX3582R T4 1.06, 66MM Compressor, 3 Inch IC Pipes,HPX, Wiseco 8-1, Ported Head, Carrillo Pro Rods, CES Cut Ring, 3.5 Exhaust, ARP, Big FMI, Turbonetics Gate Fender Exit, 2 Walbro Pumps, UUC 6 Puck Ceramic, Aluminum Flywheel. With working A/C.
