Bavarian Soundwerks
Results 1 to 5 of 5
Thread: Continuous constant noise from speakers
    Mar 2019
    ON
    BMW 2011 323i U1 SEDAN
    Exclamation Continuous constant noise from speakers
    Hello,
    This E90 323i speakers have constant noise coming,
    This speaker noise does not change with volume up or down from radio.
    Speaker noise starts right away when i put ignition key in and stays there irrespective of Engine on/off
    Noise goes off automatically 2-3minutes after I take ignition key out.
    Please play check audio I recorded coming out from speakers. I put phone microphone right on the top of speaker.
    Everything is stock on this car, Radio, speakers etc, Nothing is modded.
    https://vocaroo.com/i/s1nfJDmml9fn
    Thank you
    | Model 323i U1 | Year 2011 SEDAN | Development Code E90 (MUE) | Type PG77 | Miles 95000
    Dec 2002
    Cali
    2004 330Ci
    Sounds like electrical interference from another electronic device in the car.
    Usually when i am trying to solve NOISE. I check and clean grounding points for the radio system.
    Possible some wires are running on top of your speaker wires emitted noise into the speaker wire.
    Mar 2019
    ON
    Quote Originally Posted by bigmansM View Post
    thanks for response. I will start with ground
    Mar 2019
    ON
    I re-connected the radio wiring and the noise is gone permanently, but sometime aux is not working
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Check the male pins and female sockets in the connectors to see if they are in good condition.
  1. Continuous constant noise from speakers
    By adm1n1strator in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 01-07-2020, 07:55 PM
  2. faint high pitch noise in speaker
    By sugarjay in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-17-2004, 07:42 PM
  3. Noise from speakers
    By marko in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-02-2002, 11:11 PM
  4. White noise from speakers (possible bad ground???)
    By Mike88 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-19-2002, 05:34 PM
  5. popping noise from speaker when press on clutch
    By Saul in forum 1992 - 1999 M3 (E36)
    Last Post: 08-22-2001, 04:22 PM
