Results 1 to 4 of 4
Thread: Recommended transmission fluid for SMG
    Nov 2015
    Walla Walla, Washington
    '70 VW bus + '95 325i
    Before I get shot down with “use the factory fill” I’m curious if anyone has experience with oils that can help the smg shift less clunky. My car is at 201k miles, and It sometimes sounds like it’s shifting with a hammer. That may be an exaggeration, just normal smg things.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Redline MTL 75W-90 is a good quality replacement for the factory fill, and I am assuming you mean to go into the 6-speed, not the hydraulics.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Nov 2015
    Yep, the gearbox oil. I’ve heard good things about the royal purple synchromax. I have run redline mtl (I believe that’s what it was) in zf in my e36 and it’s notchy when cold.
    dworthy's Avatar
    Nov 2010
    I have used Royal Purple in the diff of an E-36, but not in a transmission. Also you can mix the MTL with Redline ATF to remove that "knotchyness", normally 50/50.
    Darin
    Current:
    Past:
    M-Flight Member
  1. E36 M3 Transmission Fluid Recommendation
    By tommelton in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-20-2011, 09:32 AM
  2. Transmission Fluid @ 100k Highly Recommended
    By WheelHead in forum 1999 - 2006 (E46)
    Last Post: 06-18-2010, 06:09 PM
  3. Transmission Fluid Recommendations
    By ty20404 in forum 1991 - 1999 (E36)
    Last Post: 05-27-2010, 04:12 PM
  4. Replies: 1
    Last Post: 10-05-2009, 06:41 AM
  5. Transmission Fluid Recommendations.
    By finebykris in forum 1991 - 1999 (E36)
    Last Post: 04-15-2009, 02:42 PM
