I’ve been Researching doing an engine swap to an m50b25 turbo for a few months now. I’m so what on a budget and would like some help deciding if the parts I’ve collected are worth it and if I have everything . I’m also wondering wether or no the zf320z 5spd can withstand the power of my build. I’ve added a list of the parts bellow and a rough estimate on price. With these parts in mind what could I make hp wise and what parts could I possibly do cheaper.
Full build
Turbo Part
Engine management War Chip w/ 60lb 1200
Turbo holset hx35 750
Head gasket Vac racing 400
Arp head studs 100
Intercooler + Piping Cx racing ~500
Block resurfacing machining 100
Rapid spool manifold 500
Blowoff + 46mm wastegate 400
Oil lines and oil plate 500
Oil cooler 200
Custom down-pipe 100-300
Fuel pump 250
Transmission
ZF 320z 5spd 400-700
Clutch kit ? 600-800
Engine m50b25 non VANOS
300-800
Ecu 150
Engine swap
E34 Oil pan 200
E34 Oil sump tube 70
E34 Dipstick/tube 70
E34 throttle cable 80
Engine mounts condor speed 100
Wire harness condor speed 210
Custom driveshaft ~400
Custom trans mount free fabrication
Random
Air/fuel gauge 100
Random gauges 300
Everything ~8500 no labor my work
Thanks,
Max
