Hello! I own a 1994 530i Touring with self leveling suspension. My power steering pump is beginning to make noise, and to my chagrin have discovered that no one makes a 3211141572 pump or equivalent!!! I'm open to ANY suggestions, thanks!
you can buy a new seal kit, in case the pump is from ZF, that includes the profile rings inside. When the profile gaskets are gone, metal/metal is touching and the pump makes noise. I did that here on a E32 pump with self levelling http://www.bimmerboard.com/forums/posts/526913/
http://www.bimmerboard.com/forums/posts/527187
This is fitting for the M30 and M70 engine, which have ZF power steering pumps. Is that 530 a V8 M60B30 or a M30B30 6-cylinder? The V8 probably does not have a ZF pump. The number 3211141572 does not exist/is not correct you mentioned, pls check again, must be 1 digit more. A 1994 530 with SLS has a Vickers dual pump 32411141574 http://www.realoem.com/bmw/enUS/show...diagId=32_0677
or ask master6 for a rebuild https://www.bimmerforums.com/forum/s...ng-Booster-SLS
