Results 1 to 14 of 14
Thread: E65 Differential swap into an E39 540i?
    Nov 2012
    Lewes,DE
    1997 540i
    Does anyone know if this e65 750i rear end would just bolt in to my 540i? Looks like it would
    Electric Fan conversion, 840Ci thermostat, Dinan style CAI,de-screened MAF, Dinan transmission chip, 255lph LS1 fuel pump, drilled slotted rotors, 3.15 differential, Bel rx65 radar (hard-wired). Hemi Killer!
    Nov 2017
    New Zealand
    2002 BMW E39 540I
    It won't. Different mounting points.
    Nov 2012
    Lewes,DE
    1997 540i
    Quote Originally Posted by necsis View Post
    Your positive? all the mounting points look the same though, even swapping the rear cover over to my e39 540i cover looks like all the bolts are in the exact same spots , it does appear to have an extra "ear" though on the drivers side on the front part of the diff but other than that all of the holes are the same. Picture 4 is the factory e39 540i diff, and the other pics are the e65 diff. looks like the cover from mine will bolt right on.
    Nov 2012
    Lewes,DE
    1997 540i
    11 - Inside view of diff (1).jpgs-l1600.jpglook at this, left one is the e39 540i diff and right is the e65 750i diff. So, looks like my 540i rear cover will definatly fit no problem, i just wonder if the front ear (mounting point) and the extra ear on the drivers side would clear. If so , this is a 3.38 ratio diff and would be great.
    Nov 2012
    Lewes,DE
    1997 540i
    Quote Originally Posted by ninetyseven1 View Post
    Can someone else confirm these rear ends will fit our 540i's? if so these 3.38 and 3.46 diffs are a dime a dozen and are going for less than $200.
    Oct 2015
    Washington, IL
    2003 540i6
    Here are some diagrams for you to reference.
    e65 diff
    e39 Diff
    e65 subframe
    e39 subframe
    2003 540i/6
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    It’s not gonna work.The rear mounts are narrower from each other than on the E39. Why rewrite the book??? Source out a gear and pinion and get the gearing you are looking for.
    Nov 2012
    Lewes,DE
    1997 540i
    Quote Originally Posted by BimmrMeUpSnotty View Post
    huh? rear mounts? you know the cover from the e39 fits right? the rear mounts of the diff are on the cover and i was thinking of using the e39 cover since it looks like the bolt patterns are identical. Is that what you are referring to?
    Apr 2016
    the great pacific n.w.
    540it, 540sedan, 540-6 s
    Limited slip?
    And what size rearend is the e65 classified as? 210mm 188mm?
    Reweld the cradle and go e60 m5. Lower gear and sure grip.
    Not sure these cars need lower gears though.
    Nov 2012
    Lewes,DE
    1997 540i
    Quote Originally Posted by wagons ho View Post
    Limited slip?
    The e65 is an open 210mm,
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Look at the difference in the front mount as well.
    Philadelphia, PA
    2005 M3 & 2004 330i
    Front mount looks to be further from the center than the e39
    Jan 2016
    Ca
    2001 525it
    You will have to try it and report back
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Interesting as the rear bolt pattern seems a likely match, so the rear mounts should work out. The front will need some adapter or some welding to get it to work. The DS and stubs/axles may need work too.
    The main problem is that is likely not worth the effort as this is still an open diff. Just a gear ratio change...
  1. E39 M5 limited slip differential swap into an E39 540i
    By gotodefcon62 in forum 1996 - 2003 (E39)
    Last Post: 06-01-2018, 09:00 AM
  2. E39 E39 540i 3.15 DIFFERENTIAL
    By firebird540 in forum Drivetrain & Transmission Parts
    Last Post: 09-27-2013, 09:27 AM
  3. E39 E39 540i Steptronic Transmission Automatic Differential and Parts
    By e36 bimmer in forum Drivetrain & Transmission Parts
    Last Post: 03-26-2010, 10:55 PM
  4. E39 BMW e39 540i Drive Shaft and Differential
    By applecran in forum Drivetrain & Transmission Parts
    Last Post: 07-28-2009, 01:56 AM
  5. E39 FS: E39 540i 2.81 Differential, driveshaft and halfshafts
    By EMRtek in forum Drivetrain & Transmission Parts
    Last Post: 09-28-2007, 11:38 AM
