Page 4 of 19 FirstFirst 1234567891011121314 ... LastLast
Results 76 to 100 of 463
Thread: Interest in a fully integrated A2DP Bluetooth solution?
  1. #76
    Vincentown, NJ
    E46 M3 conv, E30 325iS, E39 M5
    Quote Originally Posted by t3ddftw View Post
    It's not easy to use the OE microphone with the GROM :/. You need to provide 5v DC to it over a 2k ohm resistor and then de-couple the DC using a 47uF bi-polar capacitor. My board has these components on-board.
    I am not sure that is the case. Several people (cfr. thread on M5board) backpinned the OE plug near where the nav computer is, connected that to the GROM and lived happily ever after.
    Possibly your solution is better - I honestly didn't look into it that much, because the M5board way worked for me. Now, do I have complaints about the GROM? Sure I do. Would it be better if there were a better all-in-one, plug and play solution, with a better DAC and audio path, possibly aptX support and a few other things? Sure. I'll be glad to buy it when it's available.
  2. #77
    Feb 2012
    Vallejo, Ca
    1998 BMW 540i6
    I have a '97 750il with the tape up front, Dsp, ^ changer in the trunk and factory phone installed. Will this work?
  3. #78
    Feb 2013
    Las Vegas, NV
    2006 BMW M3
    Quote Originally Posted by S2Dinan View Post
    It should work as long as you have an IBus compatible CD Changer in the trunk. Does your car have the Nav system with the tape player?
  4. #79
    Sep 2018
    Richmond
    2000 E38 450iL
    Quote Originally Posted by nmlss2006 View Post
    dillalade, keep in mind you can use the OE mic with the GROM. With that said, it is true that the audio quality isn't the best.
    Pleas advise I how utilise the OEM microphone in the front cabin.
    I am reluctant to run that long mic cable from grim and rip seats out etc etc.
    Please if you can advise exactly how to get this to work, it would be so much appreciated.
    Currently when taking calls I need to then Bluetooth off before answering otherwise they can't hear me (because I hadn't ran that from mic from the the trunk to the front)
    Sent from my Phone 2 using Tapatalk
  5. #80
    Sep 2018
    Richmond
    2000 E38 450iL
    Yes! I ran into some issues caused by the additional functionality I added to the board -- minor stuff like there being a "crashing" noise when playback would begin. I ended up sorting these issues out.
    I have a single beta unit to another user as it stands. Right now, I'm working on an issue where-in the other end of the call is able to hear an echo of themselves if the volume of the call is too high.
    If this turns out to be a hardware issue, then I will need to have another run of PCBs made which will be to me next week. Otherwise, I will send a few more beta units out over the weekend and we will deal with the echoing by tuning the call volume and echo cancellation algorithm.
    Thanks!
    -Ted
    Hey Ted
    Hope your well
    How is this project coming along, I'm itching to try this.
    Thanks for all your efforts pal
  6. #81
    Feb 2013
    Las Vegas, NV
    2006 BMW M3
    Somehow I missed your comment -- sorry! It is possible that with enough gain, the microphone can be made useful without being powered. However, the Microphone has a built-in JFET pre-amp that does expect power. Once powered, that microphone can pick up the sound of my finger tapping on the steering wheel!
    Quote Originally Posted by dillalade View Post
    For what it's worth, you should be able to tell your phone not to route calls to BT (if it's an Android device).
    Here's the thread where using the microphone with a GROM is explained: https://www.m5board.com/threads/inst...em-mic.295049/
    Hey Ted
    Hope your well
    I've had positive feedback on Rev C, with the exception that digital DSP users are not able to use the unit. I tracked down the source of the issue and I'm waiting on a slightly updated PCB to arrive sometime next week
    so that I can ensure the issue has been resolved
    Thanks!
    -Ted
  7. #82
    Vincentown, NJ
    AFAIK the current practice as explained on M5board has the microphone plugged into the original module and backpinned. Thus, the power comes from the BMW equipment, satisfying that requirement.
    Dillalade, look on M5board, there's a (very) long thread, Ted linked to it.
  8. #83
    Feb 2013
    Las Vegas, NV
    2006 BMW M3
    Ah, that makes perfect sense then. I forget that a lot of these non-E46 cars came with TCUs/ULFs standard.
  9. #84
    Sep 2019
    austin, tx
    2001 740il - 98K miles
    Just pre-ordered one - been looking for a solution for my e38 for years.
  10. #85
    Feb 2013
    Las Vegas, NV
    2006 BMW M3
    Quote Originally Posted by moodyintx View Post
    Excellent! You'll have the Digital DSP, so just ensure that you have the coaxial cable from the Amplifier to the CD Changer somewhere in the electronics trunk-box still
    To everyone,
    I've expanded the beta group from 8 units to nearly 20 as I get ready to call it "good to go" and send it off for production manufacturing sometime in October.
    Thanks!
    -Ted
  11. #86
    PA & MI
    '01 740iL#2,'02 CBR954RR
    To everyone,
    Thanks!
    -Ted
    Nice! Hope this works as well as advertised and all indications I've read are yes!
    "A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible. There are no prima donnas in engineering." - Freeman Dyson
  12. #87
    Feb 2013
    Las Vegas, NV
    2006 BMW M3
    Quote Originally Posted by kahlilj View Post
    Thanks! It most definitely should. I'm a perfectionist, which is part of the reason this isn't yet for sale :
  13. #88
    Alpine 7even's Avatar
    Alpine 7even is offline The King Of E38 Custom BMW CCA Member
    Mar 2011
    Haymarket VA
    e38 iL, F-e38 iL, e23 L7
    What are the chances this will play well with my intravee II. wondering if i can do a dual spliced connection via the cd input and use this for bluetooth while retaining the features the intravee provides. (auto folding mirrors, live vehicle data, digital speed display etc)
    -2000 iL Individual. VF Supercharged at 12psi, Dinan MAF and TB, 6spd 420g swap, Euro under body guards, strong strut, N62 engine cover, Hydro trunk, Full suspension mods, Brembo F+R big brakes, custom headliner/interior, Bi-Xenon headlights, wide screen nav/mk4, Custom splash screen (I make them), coded video module with custom made harness, reverse camera, Intravee II, factory rear screen entertainment console, rear comms armrest, rear blower, seat back tables and writing tablet, all euro options coded on etc.
    -1997 iL. Pioneer 8500nex double din/Avic navigation, swc and dsp still functional. Reverse camera, full suspension upgrades, leather dash, console and door cards, rear blower, Re-upholstered seats, facelift sport contour seats, heated steering wheel, 750 front brakes, custom cup holder replacing the front ash tray, all euro options coded, headliner in black, rear headliner MID console.
  14. #89
    Feb 2013
    Las Vegas, NV
    2006 BMW M3
    Quote Originally Posted by Alpine 7even View Post
    Unfortunately, my unit and the Intravee II are wholly incompatible. Some of those extra's are going to come to the BlueBus, but the only one that has been added so far is one touch blinkers.
    What features, other than auto-folding mirrors and speed/RPM are you looking to get from the car?
    Thanks!
    -Ted
  15. #90
    Jul 2015
    Dallas, Texas
    98 750iL, 01 740iL
    PDC distance display is cool along with the mirrors folding while locking.
    this kit will work on early CD changer DSP cars as well? i believe GROM does not.
  16. #91
    Feb 2013
    Las Vegas, NV
    2006 BMW M3
    Quote Originally Posted by MKIVJZA80 View Post
    Yes, it works on Digital DSP (early DSP cars) out of the box
  17. #92
    San Diego, CA, USA
    1996 328i, 2001 740iL
    Ted,
    I am not sure if this has been asked before , but theoretically is it possible to route audio output from the bluebus device into the AUX input on the BMW BM53 radio as opposed to the CD changer input? I know at this point the device has a connector for the CD changer; I'm just trying to think about a way to keep the CD changer and use the currently unused AUX input instead. I don't fully understand how you have implemented your bluebus device, so forgive me if I am not clear if the device is meant to replace the CD changer on the IBus or just act as another device on the Ibus.
    From what I can tell the device will have a DSP coaxial ouput, a microphone connector, a 6 pin connector (CD changer), a IBus connector (CD changer), a USB port (for firmware update only; not for MP3 files...) -- correct?
    It is almost end of October, I am looking forward to hearing you are ready to start production!
    Thanks!
  18. #93
    Feb 2013
    Las Vegas, NV
    2006 BMW M3
    Quote Originally Posted by Thresher View Post
    Ted,
    Thanks!
    Howdy!
    It's not possible to run the BlueBus alongside the CD Changer. Unfortunately, only late model vehicles had AUX support, so building the implementation on top of that would've narrowed the supported vehicle pool dramatically.
    The BlueBus does fully emulate the CD Changer as its means of operating.
    If your head unit (Board Monitor or Business CD) has a single CD Player, that will continue to work fine.
    There is no AUX in or support for MP3s from a Flash Drive / SD Card, on the BlueBus, and I don't plan on building it out because it doesn't fit with the vision of making this a Bluetooth solution, nor is it easy to implement those features.
    On the subject of manufacturing: I have good news and bad news:
    Good news:
    1. I have a good quote for manufacture that fits within the realm of what I was expecting to pay.
    2. I have a 3D model of the plastic case for the unit almost done
    3. I have quotes for manufacture of the case
    Bad News:
    1. A couple users discovered some audio issues with the latest revision board and the Business CD system. I have altered the design already and I'll be testing the new circuit next week. I do have to get a couple of these out and tested, so it may not be until the first week of November that I start taking orders. I do not want to have units manufactured with known hardware bugs as that will just cause all of you to hate the product.
    Thanks!
    -Ted
  19. #94
    San Diego, CA, USA
    Howdy!
    Thank you for the clarification, much appreciated!
  20. #95
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    It's not possible to run the BlueBus alongside the CD Changer...
    Perhaps not with the stock C43 nav radio.
    But I thought the CD changer's 6-pin output - which uses only 3 of the 6 pins - carries just the audio signal (left/right/ground)? And the BlueBus uses the same connector, right? If so, this could easily be adapted for use in the AUX channel of a BM53 radio, allowing the CD channel to remain open.
    Of course, such a set-up would require splicing into the CD changer's power/ground/i-bus wires (3-pin plug) in order to supply both the BlueBus and CD changer (or grab power/ground from the radio).
    See BM53 radio "diagram A" of my Nav Radio Upgrade.
    So, specifically: pin CD connection cable 61-12-0-140-718 for the BM53's AUX side (see diagram A) and pair it with a black 12-pin quadlock cover. Done.
    Frankie
    Texas, USA
    frankies-bmw.com
  21. #96
    San Diego, CA, USA
    Quote Originally Posted by Frankie View Post
    This is exactly what I was thinking. Based on my limited knowledge of Ibus and what I infer from Ted's response is that the BlueBus probably appears to other devices on the IBus as the CD changer. Years ago I started to look into IBus and it seemed that different devices on Ibus had a device identifier. Purely speculation on my part, but I wonder if the BlueBus device might be identifying itself as the cd changer to other devices on IBus. If that is true, and it is configured to do so in firmware, then perhaps there would be a way to change that, and preserve the usage of the CD changer per your comments.
    Ted, as soon as your device ships, I suspect you may get lots of ideas/requests for a future "version 2" of BlueBus! :-)
  22. #97
    Jun 2014
    atlanta ga
    2001 740i
    Thus far I’ve passed on this solution due to sacrificing the cd changer. For me anyway, I spend much more time listening to full fidelity music than on phone calls or streaming while in the car. This is starting to interest me as the prospect of having both (CD and bluetooth) may be emerging.
    Just to confirm: As it stands today this unit will work with single disk CD head units, but not changers. So, if I can retrofit a single disk head unit to my ‘01 e38 (which currently only has a trunk mounted changer) I could have access to CD playback AND all this Bluetooth goodness.
  23. #98
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    Quote Originally Posted by sdb999 View Post
    Just to confirm: As it stands today this unit will work with single disk CD head units, but not changers...
    t3ddftw: please correct me if this is wrong:
    sdb999: No. The Bluebus, like so many other aftermarket devices, is designed to operate thru the CD changer channel (wires in the trunk). And all BMW's since 1996 were pre-wired for this ('89-'95 models can be upgraded). Simply select CD mode from your nav/MID to engage BlueBus.
    And like other aftermarket devices, BlueBus displaces the CD changer.
    However if you have nav, and swap the stock C43 radio (mounted in trunk) with a BM53 nav radio, you should be able to move the Bluebus over the the BM53's AUX channel as previously described. This means the CD channel remains free for use with the original changer.
    For E38 7-series without nav (and with in-dash radios), the only way to retain CD playback ability is to install the CD43 radio with in-dash CD player, and then connect the BlueBus to its CD changer input (in trunk). (E39 5-series without nav may install the CD53 in-dash radio with AUX input.)
    Frankie
    Texas, USA
    frankies-bmw.com
  24. #99
    May 2003
    Texas, USA
    '01 740i, '99 528iT
    ...what I infer from Ted's response is that the BlueBus probably appears to other devices on the IBus as the CD changer.... If that is true, and it is configured to do so in firmware, then perhaps there would be a way to change that...
    Thresher: I think the labels "CD" and "AUX", which display on your nav or MID to identify the channel in use, come from firmware in the radio and not from the device. Therefore, moving the BlueBus to the BM53's AUX channel won't change what's displayed. So...in this case, you will see "CD" when using a CD changer and "AUX" when using BlueBus.
    As an example, I'm currently using an aftermarket mp3 music device on the CD changer line, and yet my nav still displays "CD", while its buttons retain full functionality. And when streaming thru the BM53's AUX channel with an aftermarket adapter, my nav displays "AUX".
    Frankie
    Texas, USA
    frankies-bmw.com
  25. #100
    San Diego, CA, USA
    This is what I had initially hoped for, but I suspect sooner or later Ted will chime in with a comment that it is a bit more complicated.
    If I had to guess at the internal workings of the radio system, I would say when you press the mode button on the head unit and select the CD device, then further button presses on the steering wheel and/or head unit are received (by radio?) and translated to device specific commands which are then sent to the appropriate device via Ibus. In the case of selecting AUX, that would be a generic line input and other than sending volume up/down commands to the radio, there really isn't anything else you can do like pause, play, track-forward, track-backward, or seek operations that you could do with a CD device. I suspect it is the CD changer device specific commands that the BlueBus is looking for, so that it can interpret and/or forward those actions over the bluetooth connection to the attached device. Then your connected device can be instructed to track-forward, pause, play, etc...
    The one thing I would like BlueBus to be able to do and I know it won't based on several confirmations from Ted is to allow me to browse/play MP3 files on a USB. To that end, I noticed when i was looking at BMW tv tuners the other day that some screenshots I am seeing on the updated ATSC (i.e., US) devices show that you can browse USB storage and play media files. I also thought I saw something recently about Sirius configurations; is there a CD-changer by-pass capability with how the wiring harness works? These are areas where I will spend my research time next...
    With BlueBus, I will be able to replace the CD changer and TCU. Possibly with an updated/retrofitted tv tuner I can add a rear view camera capability and I might be able to browse/play MP3s.
    I remain highly interested in BlueBus. Having someone like Ted pulling all of this together is no small feat and I think this will be a very nice addition to my car. My day job is a software engineer so I can appreciate a good chunk of the work going into BlueBus. Hardware and electrical engineering have always been viewed as a mystery to me. :-) I grabbed a copy of Ted's BlueBus sourcecode from GitHub and will sift through it in whatever spare time I can find, which unfortunately isn't much these days.
  1. Iphone Snap in fully integrated with I-Drive possible solution
    By jabaroon in forum 2004-2010 (E60,E61)
    Last Post: 07-08-2010, 07:18 PM
  2. New E46 fully integrate ipod from factory?
    By old skool in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-26-2004, 07:26 PM
  3. My fully integrated BMW Sirius radio works!
    By ambishop in forum 1995 - 2001 (E38)
    Last Post: 06-24-2004, 03:47 PM
  4. fully integrated custom ipod setup
    Last Post: 05-27-2004, 04:20 PM
  5. Anyone interested in a fully-loaded Grand Cherokee???
    By Dinan330ic in forum BMW Cars For Sale / Wanted
    Last Post: 07-01-2003, 03:58 PM
