Results 1 to 3 of 3
Thread: Will an E34 M50 sedan OEM exhaust fit an E34 M50 Touring ?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Got this question by someone who is not registered here yet. As I do not own an E34, I post the details here, maybe the E34 experts can clarify that:
    I live in Canada. I’m having a surprisingly difficult time locating an exhaust system (catback) for my car. I have researched for two weeks, without discovering a clear answer. The VIN is WBAHJ631XNG E34 M50 type code HJ63, prod. date 04/1992. RealOEM shows center muffler 18121427802 which supersedes 181217286 ,rear muffler 18101705761 which supersedes 18121427800, 18121744126, and 18121728625
    Numbers for the sedan, same month of production are one 1 number up : center muffler 18121427801, Rear muffler 18101705760 .The Catalytic converter numbers also differ by one between the touring and the sedan :Touring : 18301728616, Sedan 18301728417
    However the gasket ring sizes for the coupling between the cat and the center muffler are identical for both sedan and touring : 47 mm on the driver side tube and 50 mm on the passenger tube , which suggests that the diameters are the same. The flange for the coupling has the same part number for both sedan and touring as well.
    Bottom line : I can locate the OEM (Eberspacher) exhaust in the US for the sedan but not for the touring. Are they the same ?
    Jan 2003
    Bay Area, Ca.
    94 M5T
    i can tell you that an e34 M5 sedan exhaust fit's an e34 m5 touring, despite slightly different part numbers. From that i'd think a m50 sedan exhaust should physically fit a touring with same engine.
    Mike
    93 M5 3.8 Sterling Silver/Black (euro)
    94 M5 Touring Madeiraschwarz/Black
    80 745i (project)
    83 735i / 5 speed (euro)
    86 745i
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
  1. e34 540 center piece exhaust fit on m5 ?
    By bmw5351s in forum 1988 - 1996 (E34)
    Last Post: 02-27-2018, 06:38 PM
  2. BMW E36 OBDI M50/S50 OEM Exhaust Manifolds $80 shipped
    By blackhawkimpact in forum Engines, Performance Parts & Software
    Last Post: 01-09-2015, 11:05 PM
  3. OEM EXHAUST FITS 2012 2013 2014 2015 335 OR 435 - No Longer Available
    By stinger667 in forum Engines, Performance Parts & Software
    Last Post: 11-03-2014, 11:09 AM
  4. BMW E36 E34 OBDI M50/S50 OEM Exhaust Manifolds - No Longer Available
    Last Post: 10-07-2014, 11:36 PM
  5. Would this exhaust fit my E34???
    By Andryuha in forum 1988 - 1996 (E34)
    Last Post: 02-04-2005, 07:10 PM
