Just starting on my second turbo build starting with a 2001 Z3 with M54B30 and have all the hardware but need tuning. I would like to try a MEGASQUIRT-3 Has anyone done this on a M54.
Thanks for any help.
2001 Z3M S52 OBX T4 Top Mount, GTX3582R T4 1.06, 66MM Compressor, 3 Inch IC Pipes,HPX, Wiseco 8-1, Ported Head, Carrillo Pro Rods, CES Cut Ring, 3.5 Exhaust, ARP, Big FMI, Turbonetics Gate Fender Exit, 2 Walbro Pumps, UUC 6 Puck Ceramic, Aluminum Flywheel. With working A/C.
It doesn't have a MS43?
It's been done before. The two main "gotchas":
You'll either need to convert to a cable operated throttle body, or use the stock ECU for the drive by wire.
The VANOS solenoids need 12 volt power, while the outputs from the MS are ground switched. An external high side driver module like the HSD4 is the easy option here. I've also seen things taken apart to pull the diodes out of the wiring to allow for ground switching, but that's a lot more work.
Matt Cramer
1997 BMW 328i convertible, 1972 Chevy C10 pickup, 1966 Dodge Dart slant six
BMW - where "Why doesn't everybody build cars the way they do?" meets "Why can't they build a car the same way everyone else does it?"
Yes its MS-43
OK Cable operated throttle body is no problem, I wonder if a M50 Intake will bolt to a M54 head? VANOS can be done with HSD4 i can do that. Will the stock ECU be needed for anything else or is it removed from the car with the megasquirt-3 ?. Thanks for the help guys.
M50 conversion is done on the M54 quite a lot. I haven't researched too much about it but I do know that this exists https://www.seemslegitgarage.com/pro...ld-adapter-kit
You can remove 2 studs on the m54 head and put the m50 manifold on. I recommend porting the head to match
You will need 2 cam inputs on the MS3. I haven't personally done it but I would assume plenty of people have.
Tuning the vanos will take some time. Compensating for oil viscosity changes etc..
Alot of people run AEM pnp on the s54's. The vanos is similar, wouldnt hurt to poke through the aem base tune and see if any of it would be a good starting point for your M54.
I have a complete obd2 M50 turbo set up in a car running with MS41 Tuned for turbo making 500whp is there a way to run the M54 with this DME ? i even have a extra MS41 engine harness i could use. Just a thought..
I'd suggest just trying to copy over what's been done to the MS41 tune wise. MS43 has come quite a long way although not everything is fully defined yet. MS4x.net
