Results 1 to 7 of 7
Thread: 4 spoke to 3 spoke Steering wheel swap
    Oct 2014
    Rochester, NY
    1998 Z3
    I am planning to do the 4 spoke to 3 spoke steering wheel swap on my 98. I purchased a 3 spoke wheel with the proper single stage airbag and clock spring already.
    Will I need any other parts for this?
    What should the bolt be torqued down to after the wheel is swapped?
    Is there any advice for doing this from someone who might have already?
    Thanks.
    1998 Z3 1.9L Dinan Stage 3.
    Fort Worth, TX
    E36M3/E46M3/E39M5/E63M6
    Disconnect the battery before you begin. Torque bolt to 63nm.(46 ft/lbs).
    Its a very straightforward swap. Should not take more than 15-20 min.
    E36/8 2000 M Coupe Cosmos Black/Black
    Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
    May 2015
    Springfield Il
    '97 Z3
    10 Wheel.jpgI upgraded to a 3 spoke wheel earlier this year. Like they previous poster stated its a 15 minute job. You could have reused the clock spring from the 4 spoke wheel as they are the same. Here is a write up on the job. If you don't have a torque wrench, just get it good and tight.
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Easiest swap ever. I just marked the splines with a Sharpie before removal to make sure I got lined up again. If you somehow mess up, it's ONE bolt. Fitting the wheel takes less time than bolting the airbag back on.
    Nathan in Denver
    Oct 2014
    Rochester, NY
    1998 Z3
    Thanks. I plan to tackle this as soon as I get the car out of storage. Good to hear it is relatively easy
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    Ok. I’ll play devils advocate. Do we know who makes the airbag for these replacement wheels ? I hope you’re not getting someone’s takata reject.
    SW Florida
    99-01 M Cpe & Rdts, X5M
    Quote Originally Posted by z3forlife View Post
    None of the Z3 models were ever in the initial or subsequent recalls, so I think it's safe to say NO here (and there is TOO MUCH evidence already of deployed airbags as a result of collisions, without them adding personal injury).
  1. 4-Spoke to 3-Spoke M Sport Steering Wheel DIY Swap
    By JRCM5 in forum 1996 - 2003 (E39)
    Last Post: 04-09-2010, 02:03 PM
  2. 4 To 3 Spoke Steering Wheel Swap
    By volksfragen in forum 1999 - 2006 (E46)
    Last Post: 02-20-2010, 09:43 PM
  3. 4-Spoke to 3-Spoke M Steering Wheel Swap
    By Qsilver7 in forum 1996 - 2003 (E39)
    Last Post: 09-01-2009, 05:06 PM
  4. DIY: M3 (4 spoke) steering wheel swap from 3 series (328i)
    By wannaMMM in forum 1991 - 1999 (E36)
    Last Post: 05-04-2009, 05:59 PM
  5. 3-Spoke Steering Wheel swap conundrum
    By noahabel in forum 1992 - 1999 M3 (E36)
    Last Post: 04-30-2008, 07:15 AM
