Results 1 to 8 of 8
Thread: Lifter replacement
    Feb 2019
    Florida
    1995 BMW 325i
    Lifter replacement
    Hey guys, so I'm in the process of replacing my lifters. Everything is already disassembled and ready for a cleaning, and i have a few questions before I put everything back together. First, is there anything I should avoid cleaning? Anything i should just go ahead and replace while I'm in there (engine has 160xxx on it)? And is there anything I should go ahead and look over while everything is out? Feel free to answer any other unasked questions you might feel are relevant too. Thanks guys!
    Also, my engine did not come with a spring diaphragm or a 2mm spacer for the intake cam gear/vanos input shaft. What are the benefits to adding these two parts in? Is it a direct fit or will it need modification to make work. Is it even worth the hassle?
    Jun 2010
    NY
    1997 328i
    You already bought new lifters? Because they can be disassembled and cleaned out, usually they will work like new again. Some lifters are physically damaged and those would be replaced.
    Is the oil pan off? If it is then read up on securing the oil pump nut. Also there's the option to upgrade to a Z3 oil pickup tube.
    Feb 2019
    Florida
    1995 BMW 325i
    I was originally going to clean them, but they dropped out when i removed the cam tray, the magnets I was using to secure the lifters weren't as strong as i anticipated
    Apr 2015
    Tennessee
    1998 BMW 328i
    New is never a bad idea. The only reason people advise cleaning instead of replacing is because they are young and on a tight budget. I'm one of those people that if im doing the work I want to do it right with all new parts.
    While you're in for the lifters, check out your timing chain tensioners, vanos unit, and valve cover gasket when you button it all up.
    Jun 2016
    California
    E36 325is
    Quote Originally Posted by XnWarden View Post
    There is more truth to that then not. If you are in there already, might as well do it right.
    Feb 2019
    Florida
    1995 BMW 325i
    Thanks for the input guys. Funny how alike our mindsets are, all the parts you listed I just ordered yesterday! I do plan on reusing the lower tensioner, would you advise against this?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Ina lifters are about $12 each, but that is $288 for 24 so it does add up, but I agree it’s not a bad idea to refurbish a 20 year old valve train if you can afford to.
    Feb 2019
    Florida
    1995 BMW 325i
    Hey guys, so all parts are in and I'm nearing reassembly. I have a couple questions: first, what break in oil should I use, and what non-synthetic oil should I use along with the break in oil? How soon until I can switch back to synthetic oil? I've read that lifters should not be pumped up prior to installation, despite the video I've been using stating to do so. Is this true? Also, when it comes to priming the oiling system, how should I go about this? Thanks guys.
  1. A few questions about lifter replacement on 91 750iL
    By nateb603 in forum 1988 - 1994 (E32)
    Last Post: 09-06-2010, 04:06 AM
  2. 318i Hydralic lifter replacment
    By Gordo318 in forum 1991 - 1999 (E36)
    Last Post: 04-16-2010, 02:42 AM
  3. Need Help With a Lifter Replacement
    By Kraut.Burner in forum 1991 - 1999 (E36)
    Last Post: 03-19-2009, 01:46 AM
  4. Window Lifter Replacement Question
    By boink in forum 1991 - 1999 (E36)
    Last Post: 03-03-2008, 12:02 AM
  5. Lifter replacement write up?
    By speedlust in forum 1992 - 1999 M3 (E36)
    Last Post: 10-09-2007, 11:10 PM
