Results 1 to 10 of 10
Thread: Second pair of rear calipers.
    Mar 2019
    Pland
    E39
    Hey guys. I'm using rear suspension from E39 in my project, and I'm wondering: Does someone put second pair of calipers for hand brake?
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    How you going to mount the second set of calipers?
    Jan 2015
    Shreveport Louisiana
    e brake is a drum brake internal to the rotor, cable operated by the lever. i do remember seeing a post on the other forum quite a while ago by an eastern European who did add a second caliper (for some reason) to change the e brake to hydraulic, with all the machining specs parts etc.
    San Jose, CA
    1997 BMW 540i 6 speed
    Have you actually examined the rear suspension? If so, you will have discovered the parking brake.
    Mar 2019
    Pland
    E39
    I'm not asking about parking brake, I need second set for hydraulic brake, drift etc
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Vladim View Post
    You probably could simply us a more aggressive pad in the rear
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    I believe what the OP is asking how would one install a second set of calipers for a special application use, i.e. to lock the rear wheels on a corner for sliding the rear around- AKA Drifting. All you will need is some fabrication skills and a caliper (Small and easy one-two bolt mount up)
    Wilwood calipers should have something you are looking for. https://www.wilwood.com/Calipers/CaliperListLanding
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    JimLev's Avatar
    Sundance Mesa, NM
    Lots of fab work required.
    Maybe modify the hydraulic system and add 2 levers with their own hydraulic cylinders.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    I think that second one in that image is a parking caliper....
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    JimLev's Avatar
    Sundance Mesa, NM
    Quote Originally Posted by StephenVA View Post
    Yes, it is. It's an option on the car I'm building.
  1. E46 For Sale : E46 M3 Pair of Rear calipers and Brake Booster
    By Bluegrass in forum Brake Kits, Rotors & Pads
    Last Post: 05-18-2018, 09:51 AM
  2. Rear caliper upgrade, E36 M3; what to pair with Brembo fronts?
    By aeronaut in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-11-2016, 12:00 PM
  3. E34 Free for the taking: Pair of Rear e34 Calipers
    By mistanate in forum Brake Kits, Rotors & Pads
    Last Post: 03-22-2013, 12:15 AM
  4. E31 Pair of New(reman) rear calipers
    By legoman67 in forum Parts for Sale
    Last Post: 04-29-2012, 04:33 PM
  5. E36 318 ti rear calipers... does anyone here have a pair for sale?
    By Bolidoendiablad in forum New England - US
    Last Post: 12-06-2007, 08:09 PM
