Results 1 to 3 of 3
Thread: M50 high compression turbo build
    May 2015
    Dallas
    1995 BMW 540i
    So I was going to get reground cams to get more valve duration and also was thinking of running 10.5:1 compression ratio with about 5-6 psi boost
    Does this sound like a good idea or are there any downsides to this?
    Apr 2006
    Minnesota eh?
    86 325es
    If your going to run E85 you won't have an issue. Could probably be done with 91 or 93 if your careful.
    May 2015
    Dallas
    1995 BMW 540i
    Hmmm I had talked to a few people and I’ve settled on 9:1 compression with premium gas. Next thing I need to look for is finding out if I need to get mega squirt or if the red label ecu can be tuned for turbo.
  1. Miller WAR Machine - High compression S50 Build
    By Brody @ Miller in forum 1992 - 1999 M3 (E36)
    Last Post: 08-17-2018, 01:59 AM
  2. Replies: 150
    Last Post: 02-20-2016, 06:56 PM
  3. M50 high compression oem parts build, need help choosing some parts
    By Blackhunter in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-02-2014, 08:00 PM
  4. High compression engine build
    By Shipper in forum 1976 - 1989 (E24)
    Last Post: 02-28-2013, 08:27 PM
  5. High compression engine build Part 2
    Last Post: 11-13-2012, 10:18 PM
