Results 1 to 4 of 4
Thread: 1990 525i oil pressure switch
    Aug 2009
    HONOLULU, HAWAII
    1990 e34 525i
    Greetings everyone. I'm trying to take out a leaking oil pressure switch on my 1990 525i. The 22mm deep socket does not fit the switch. Do I need a thinner socket? Because the 22mm socket fits the new switch on hand. I'm thinking because of tight clearance of the oil pressure switch pocket I need something thinner. Any help is greatly appreciated.
    May 2017
    Perth, Western Australia
    09/90 E34 525i (M50)
    Quote Originally Posted by limj019 View Post
    From what I read a regular thickness socket will fit clearance wise.
    I think you've fallen into a trap and assume the old switch is 22mm. I'm pretty sure it's not and depending on year or model it may be 23mm or 24mm
    E: I've seen people on e30 vids use a 15/16" so try one fit - if you already have one.
    Aug 2009
    HONOLULU, HAWAII
    1990 e34 525i
    Quote Originally Posted by fo3 View Post
    Thanks mate for the reply. That's exactly what I was thinking. I've seen the e30 vid and tried my 15/16 impact socket but I suspect that socket is a little too thick. I'll try a 23mm or a 24mm. Thanks again have a g'day.
    Aug 2009
    HONOLULU, HAWAII
    1990 e34 525i
    IMG_20190325_113022963.jpgIMG_20190325_112939739_HDR.jpgIMG_20190325_112905888_HDR.jpgIMG_20190325_112905888_HDR.jpg
    You were right fo3. The pressure switch on the pan was a 24mm. It is a TRW made in Germany. I guess it's OEM. The new one is a 22mm FAE. I wonder how long this will last before leaking. The TRW lasted around 13 years. My project was to change the switch and rethread the oil pan drain hole. Was a bit nervous about rethreading but it turned out good. I used the Lisle tool. So all I have to do today is clean the drive way. Thanks for your intput fo3. I hope this helps. Bye for now.
    Attachment 648203
    Sorry, I forgot the TRW logo.
  1. Changing oil pressure switch
    By apex003 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-02-2007, 07:40 PM
  2. Wtb Oil Pressure Switch
    By Corra in forum BMW Parts Wanted
    Last Post: 02-08-2007, 01:02 PM
  3. 1986 528e Oil Pressure Switch Replacement
    By indigowhale in forum 1982 - 1988 (E28)
    Last Post: 09-07-2006, 10:23 AM
  4. Replacing Oil Pressure Switch
    By ukray in forum 1996 - 2003 (E39)
    Last Post: 08-12-2005, 11:02 AM
  5. Oil pressure switch on the M42 engine???
    By Gonzo318is in forum 1983 - 1991 (E30)
    Last Post: 12-24-2004, 12:47 PM
