Results 1 to 10 of 10
Thread: No power to Fuel Pump Fuse or fuel pressure
    Jul 2018
    La Crosse, WI
    1998 BMW 328i
    I drove my '98 BMW 328i from work fine, but next time I tried to start it, it would crank, but it wouldn't start. I checked the injectors, and I wasn't getting pressure, so I've replaced both the Fuel Pump and the Fuel Pump Relay.
    I've also examined the DME, and it looks to be in fine condition.
    The fuse (#18) looks fine and has continuity, but it doesn't receive any power. I'm not sure what I should be looking for to see what's causing this. It's my daily driver, so I'd like to get this fixed soon.
    Jun 2010
    NY
    1997 328i
    What's up Harvey, welcome to the forum!
    Great diagnostic work so far. You've 99% confirmed your Cam sensor is bad. It's important to get an OEM part for this, Siemens/VDO are OEM'ers for this part.
    There are few places to buy one but the cheapest I've found is an ebay seller that does high volume, you can use the 800 number to order from them directly. You can also ask for a better price, but do that in the beginning of the conversation. Reference the ebay auction number and get them to verbally verify that it's the VDO part.
    Just for future reference, cam sensor controls fuel, crank sensor controls spark.
    https://www.ebay.com/itm/For-BMW-323...O/351443945643
    Jul 2018
    La Crosse, WI
    1998 BMW 328i
    My car isn't throwing any codes at all. Would a bad cam sensor not throw one? Also, are there any other possible causes I should look into?
    Jan 2019
    HK
    Harvey, jump your fuel pump relay with a wire, and see if fuel flows to the rail, and current flows through your fuel pump fuse. Then check your crank sensor's resistance and confirm that it is within range (please google for the resistance info).
    Jul 2018
    La Crosse, WI
    1998 BMW 328i
    I'm just learning automotive work with Harvey (my car). Can you link an article on how to safely jump the relay?
    Jan 2019
    HK
    Please check on youtube and google. This issue is covered in many places.
    Wisconsin
    98 328IS 03 325xi
    Bad sensors wouldn't cut off power to the fuel pump unless the EWS system does that. Try applying power directly to the fuel pump to see if it will start.
    Gave away my BMWs, driving a VW and an Audi now.
    Jan 2019
    HK
    Quote Originally Posted by jmo69 View Post
    jumping the relay will do exactly that.
    Sep 2018
    KwaZulu Natal, S. Africa
    E30 325i and E34 525i
    Try and clean the sensor. Maybe it just got a bit of dirt stuck in it.
    Wisconsin
    98 328IS 03 325xi
    Quote Originally Posted by DANLOBO View Post
    What sensor supplies power to the fuel pump? None that I know of. Cam sensor fires the injectors.
  1. E36 318i Problem with power going to Fuel pump fuse and fuel pump
    By mymrfluffums in forum 1991 - 1999 (E36)
    Last Post: 02-28-2021, 04:57 AM
  2. 95 318i no power at fuel pump fuse
    By glenl in forum 1991 - 1999 (E36)
    Last Post: 02-28-2012, 06:45 PM
  3. Another No Power To Fuel Pump Fuse Thread
    By pearliroc in forum 1992 - 1999 M3 (E36)
    Last Post: 12-28-2011, 04:25 AM
  4. 540i no power at fuel pump fuse ?
    By Rossd in forum 1988 - 1996 (E34)
    Last Post: 09-14-2010, 12:07 PM
  5. No power at fuel pump fuse
    By 94 530i in forum 1988 - 1996 (E34)
    Last Post: 12-12-2009, 02:56 AM
