Results 1 to 7 of 7
Thread: 2004 iDrive Screen Replacement
    Chicago, IL
    '09 X6 - '04 745Li
    Just yesterday my iDrive screen started to flicker (photo attached) so it's time for replacement. I've seen YouTube videos and doesn't seem complicated.
    My question is, I have seen ads for Android replacement of the screen. What is the benefit gained of going with Android vs OEM? I'm not really sure I intend to keep the car much longer, I don't plan on making any other modifications to the car.2004 BMW 745Li iDrive Screen.jpg
    Used OEM iDrive screens on eBay around $150.00 vs Android screens $500.00- $800.00 - WOW
    '09 X6
    '04 745Li
    '97 Z3 1.9L
    '94 740iL
    '88 528e
    '94 Jaguar XJS
    '85 MB 380SL
    Jan 2016
    Ca
    2001 525it
    You should look up bavtek online and see if they sell a replacement, it is just a screen
    Oulu, Finland
    See my sig
    Changing the screen itself is easy task. Go for facelift MMI and you get better graphics and option to get aux input in future (needs 2007-2008 ASK and facelift fm tuner along with the screen).
    I changed the screen to facelift one few months back. Of course it does need coding after replacing it.
    I got the original MMI (screen) from my car I could sell it cheap, but I think the shipping cost would be kinda high to Chicago.
    Current rides: E65 730dA '04, F10 520dA '11, E34 520iA '91
    Old rides: E46 316Ti, E53 X5, E38 728iA, E39 528iA, E46 318i Touring, E38 730dA, E36 316i, E36 328iA Cabrio, E38 728i, E38 750i, E36/3 320i, E36 318i, E39 530dA Touring, E38 740i, E39 528iA, E34 525iA, E32 750iL, E32 730iL, E34/2 525TDS,
    E34 525i, E28 518i, E34 535i, E34/2 525iA, E30/5 325i, E34 535i, E28 520i https://www.instagram.com/zener__/
    Aug 2018
    Sweden
    BMW 730i
    Quote Originally Posted by zener View Post
    You should be able to just update the pre facelift MMI (screen) to the facelift interface with winkfp. All the MMIs use basically the same hardware throughout all years.
    I have never done it myself but have spoken to a guy who has.
    use winkfp to flash the new firmware to the module. You need to go to advanced options and specifiy the newer version of the software with the older load file.
    I have also spent some time reverse engineering the MMI so no real difference between the hardware.
    Skickat från min SM-G955F via Tapatalk
    Oulu, Finland
    See my sig
    Guess, that could work also. Gotta try to update my old screen and see what happens.
    Aug 2018
    Sweden
    BMW 730i
    As for the original question if you have aux in for sound the android unit can be used as a bluetooth interface and some other features depending on what you already have and all the functions that you would find in any Android device. And you shouldn't loose any of the original idrive functions as it should be still accessible in some way (I don't have the Android unit so this is just what I've heard).
    But depending on if it's the lcd screen or the actual MMI that is causing the flickering you may still need a new MMI unit. Because if I remember correctly the Android unit just replaces the lcd screen and is connected to the MMI computer so that is still needed for all of the original idrive functions and probably power to the Android unit.
    The size of the LCD display is 8.8 inches (diagonal). A 6.5-inch
    display is planned as a future option.
    The casing is designed to be able to accommodate all screen
    sizes offered.
    The complete Control Display assembly is fixed to the
    dashboard by three screws.
    The LCD display plus the screen cowl and glass cover form a
    detachable unit.
    Service information:
    This means that if the glass cover becomes scratched, for
    example, the LCD display and screen cowl can be replaced
    separately.
    The LCD display plus screen cowl clips onto the metal casing.
    A special tool is required to separate the two components.
    Internally, the LCD display is connected to the electronic module
    by a ribbon cable.
    Aug 2018
    Sweden
    BMW 730i
    I would guess that it's the FPGA (visible in the lower left corner) that has thrown in the towel as that's what outputs the picture to the lcd.
    Or it could be the the lcd assembly (hard to tell).
  1. Replies: 0
    Last Post: 03-27-2014, 06:54 PM
  2. Cracked iDrive screen...need help finding replacement and/or p/n
    By mpwr ren rebel in forum 2004-2010 (E60,E61)
    Last Post: 07-02-2012, 05:17 PM
  3. Replacing iDrive Screen Question w/Pics
    By EdZorX in forum 2004-2010 (E60,E61)
    Last Post: 03-22-2012, 12:08 AM
  4. E46 2004 Fog lights replacement
    By boyans in forum 1999 - 2006 (E46)
    Last Post: 11-06-2006, 09:56 PM
  5. new farehiet screen replace 7000hrs (pics)
    By schnitzed328 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-05-2005, 07:00 AM
