Results 1 to 11 of 11
Thread: M3 overheating after clutch fan install
    Dec 2017
    Tampa, Florida
    1990 BMW 535i
    Well, just put in a new clutch fan which is working now because I tried using the newspaper trick and it batted it away. but when im at idle im still overheating unless i 2k RPM the car.
    Thermostat worth checking? Kinda lost, no idea what else it could be.
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Thermostat. Inefficient water pump. Do you know the last time these were replaced?
    Aug 2013
    1999 BMW M3 Coupe
    Drain the coolant from the block and rad and do the thermostat and water pump, at a minimum, with a new OEM plastic thermostat housing. If you haven't done it yet, at least one of them probably needs replacing. I'd suggest springing for the Stewart pump if you're going to be replacing it, or at least an OEM metal impeller pump.
    You should also replace as many coolant hoses and hose clamps as you can easily get at since they're not expensive and it saves you from having to do another coolant drain to address a leak in the future. Also take a look at your radiator (if it's OEM) for any leaks or cracking. The plastic necks like to crack after a long time. The expansion tank is also worth inspecting as it's easy to replace while doing all this other stuff.
    Oct 2003
    Seattle
    99 M3
    ^+1
    Quote Originally Posted by TostitoBandito View Post
    Use a Stainless Steel stamped/welded sheet metal impeller pump IF you go metal, as that is the impeller type BMW went to when they began having plastic impeller failures.
    The SS pumps were replaced with a composite impeller pump.
    I have heard that Saleri is the OE pump.
    https://www.dvatp.com/bmw/water_pump
    https://www.ecstuning.com/BMW-E36-32...ng/Water_Pump/
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Quote Originally Posted by bluptgm3 View Post
    ^+1
    I disagree on the welded sheet metal ones ... I've seen them fall apart and the metal bits in the engine are definitely not cool! The OEM new plastic ones are fine. Stewart for a do once and forget for sure.
    Check out the 8legs Racing page: https://www.facebook.com/8legsRacing/
    Dec 2005
    Virginia
    1997 M3, 2012 C63
    Any of the water pumps you can buy on the big parts sites will be fine. They stopped selling the plastic ones that can break apart 15+ years ago...
    Having gone through numerous water pumps, I would recommend the stewart just because it doesn't cost that much more money, should last longer, and provides more flow.
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by realjones View Post
    The Stewart I installed only lasted 100k and did not qualify for their “Limited Lifetime Warranty”
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Really? That's surprising ... why did they deny the claim?
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by ScotcH View Post
    LIMITED WARRANTY/DISCLAIMER
    Stewart guarantees that its products are free from defects in faulty workmanship and defective materials only if it is determined to Stewart's sole satisfaction that the products are, and have been subjected to, ordinary use and service and have been properly installed by the purchaser (see tag attached to product). If any product fails to conform to these warranties Stewart will, at its sole option and as its sole and exclusive liability hereunder, for a period of one year from the actual date of purchase, repair or replace the product
    Ottawa, ON, Canada
    e90 M3,X5,e46 racer
    Lol, I guess noone has actually read the warranty. So not lifetime at all. Must say, I'm disappointed. But I've also never had them fail, so I dunno ....
    Aug 2013
    1999 BMW M3 Coupe
    Yeah, aside from this case I've never heard of any issues with the Stewart pump, and it's worth mentioning that in this example it did run for over 100K miles so I don't think you can call it defective (also probably why the warranty claim failed). Obviously I'd expect this pump to last well over 100K miles more often than not though. That said, I bet if someone contacted Stewart with a failed pump which had only like 20K miles and a few years on it they might actually replace it regardless of what the fine print says. That's clearly a defect, whereas the 100K mile failure is more ambiguous.
  1. Electrical Fan after Clutch Fan Removal
    By peezen in forum 8 Series (E31)
    Last Post: 07-27-2015, 03:16 AM
  2. '98 740iL E38 Still Overheating After Clutch Fan Is Replaced
    By Berncurio21 in forum 1995 - 2001 (E38)
    Last Post: 11-02-2014, 10:31 AM
  3. '98 740iL E38 Still Overheating After Clutch Fan Is Replaced
    By Berncurio21 in forum Forum Software Questions & Suggestions
    Last Post: 10-03-2014, 01:12 PM
  4. Overheating after Bimmerworld fan delete mod
    By Track This in forum 1991 - 1999 (E36)
    Last Post: 12-03-2011, 04:40 AM
  5. after market fan install
    By rt turbo in forum Engines, Performance Parts & Software
    Last Post: 04-18-2008, 09:45 AM
