Results 1 to 13 of 13
Thread: Coolant Flow Diagram
    May 2014
    Vancouver,WA
    00 Maxima SE
    So, this is kinda silly questions. Does anyone have the flow diagram of the coolant path in our E36 M (S52)?
    I already asked in respond to another thread but perhaps I can get answer here since we have more traffic here.
    This started as I was looking to mount my water temp sending unit. So far, other than doing it in the head, which mine didn't have any extra port, is to do in the t-stat housing. I found this pic, which looks like the sender it is placed in the flow of the upper radiator hose (NOT in the direction of the thermostat opening).
    Attachment 648019
    Based on the pic above, the upper radiator hose would carry the "hot" coolant goes in the radiator but If I understand how the thermostat works, the thermostat sensing part is in the engine head, which in this case in the flow path of the lower radiator hose NOT the upper radiator hose. UNLESS there is an opening/by pass on the block where the hot coolant goes to the thermostat side of the housing and activates it when it reaches certain temperature and retracts the thermostat open to allow the cold coolant from the radiator to go to the engine.
    so, which diagram is it?
    This
    or This
    or???
    FEEDBACK THREAD
    00-03 Nissan Maxima HID Retrofit
    6th gen AV6 FX35 Retrofit
    Chassis and Suspension
    2011 Space Grey E82 N55 DCT
    2000 Sunlit Sand Maxima SE 5Spd.
    1997 Arctic Silver E36 M3/4/5.
    1997 Techno Violet E36 M3 Coupe 5Spd (SOLD).
    Oct 2003
    Seattle
    99 M3
    Your second diagram is more correct.
    This is the M54, M52 is similar -
    https://www.bimmerfest.com/forums/sh.../topics/449008
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    There is a small bypass hole in the thermostat housing. I have mounted a 1/8 NPT sender there before and it has worked. You can also get an adapter fitting to use the throttle body heater port in the head if you are no longer heating your TB. Many have gotten rid of the heater circuit with no ill effects. Mine has been gone for over 10 years and I drive in winter in NH.
    M54 actually flows a bit differently as far as specific routing... but its the same as far as which hose is hot/cold
    The upper hose is the hot hose on every BMW I've worked on. Makes sense to me, heat rises after all, so have the hot inlet on top of the radiator and take the cool coolant out at the bottom.
    I also imagine you'd want the sensor on the cold side of the thermostat. If its supposed to regulate anything, you'll want to be regulating the temperature of the coolant going into the engine - not coming out. So the picture with the sensor in the housing does look wrong to me. Though - we don't know what their intended use for it was, maybe they had a reason for that, or maybe they just wanted to measure coolant outlet temps...
    PRICE CUT on ALL FABRICS
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by BimmerBreaker View Post
    I would want to know temperature of coolant coming out of the head/block to validate that the cooling system is working as intended.
    Quote Originally Posted by bluptgm3 View Post
    I imagine most people doing this are looking for something to trigger an aux fan or supply tertiary data to the driver - and knowing the temp of the coolant going into the engine is much more useful than knowing the temp of what is coming out.
    But to humor your statement - wouldn't it stand to reason that the coolant going into the engine determines the cooling efficiency of the engine much more than the coolant outlet temp? The outlet temp will be hot no matter what the cooling system is doing, ie. if its operating well or totally failed, the outlet will be hot - but if the coolant inlet temperature starts creeping up, you know the cooling system is no longer operating properly. The coolant outlet doesn't really matter in an abstract sense, all that matters is that after the outlet, the water pump pushes it through the radiator where it is cooled and enters the engine again. It's that process - the cooling - that is critical, and that is what would be measured by a coolant inlet temp sensor.
    The only time I'd personally find a coolant outlet temp sensor useful, is if I also had a coolant inlet temperature sensor so I could compare the two values and see how much heat the coolant is taking from the engine
    BKLYN, NY
    98 M3/4/6, 16 M3/6
    If your thermostat is stuck closed, it will always read cool and you will overheat. Your gauge will seem like everything is good but its not.
    May 2014
    Vancouver,WA
    00 Maxima SE
    For me, the additional water temp gage is to make sure that I have enough warning when the engine temp start to creep up, putting it in the block at the hottest section would make sense but that seems way too much work for now. So, seems like the putting the temp sender on the hot side of the thermostat housing is the next best choice. Although I like the idea of having another temp sensor to monitor the cooling system efficiency, but perhaps that's for another day.
    Thanks guys.
    FEEDBACK THREAD
    Jun 2005
    New England
    This is out of stock but you get the idea and can find other parts to make your own.
    http://www.trmtuning.com/product/trm...-temp-adapter/
    You do need a sender that fits and some are too long or too fat and will bottom out in the adapter or not fit through it.
    There are also universal sender holders that fit in the upper radiator hose. Cut the hose and insert it. I forget the size of our hoses. 1.375? 1.5? 1.625?
    If you have two fans, separately controlled and properly installed, you really don’t need to worry.
    Quote Originally Posted by Genes1s View Post
    Thanks guys.
    If you want a warning, shouldnt you be monitoring the inlet? Monitoring the outlet seems like it would tell you of an overheat condition after it happened. Inlet, you could see that the "cool" coolant isnt as cool as it should be and catch it before it becomes an issue. I guess I just dont personally see the point to monitoring the outlet, but as long as it makes sense to you...
    May 2014
    Vancouver,WA
    00 Maxima SE
    If you monitor the inlet, you are monitoring how the cooling system "cools" the hot coolant, right? Lets just say, that the coolant reading in the inlet is high, technically it could be 2 things, the cooling system isn't capable/have issue or you have engine that is already overheated. IF you have an engine that is already overheated and you see the temp reading at the inlet of the T-Stat is 70C, the actual temp at the engine be will much higher (if the cooling system is OK). So, to me, this gives me false reading of the actual engine coolant temp in the engine.
    If I'm reading it right after it comes out the engine, I have the best chance to catch the actual reading even though the overheating is already happening. The best chance to do this is actually on the cylinder head like how the factory does it but like I mentioned I don't have any spare plugs and not sure if I want to delete TB coolant hose.
    Having both would be handy. You can find the delta and you can see how efficient your engine and your coolant system performing by comparing the temp before - after - before.
    my 2 cents
    FEEDBACK THREAD
    Jun 2005
    New England
    If my water pump failed, I would want to know sooner rather than later. The cold side of the radiator might be 20F colder than the hot side.
    Jan 2003
    USA
    BMW M3
    Always want to have the sensor closer to heat source so in case of overheating it will be detected sooner. I would constantly want to know what is the highest temp in the engine.
  1. M60 engine coolant flow direction diagram ?
    By 84318i in forum 1988 - 1996 (E34)
    Last Post: 04-06-2018, 08:46 PM
  2. Coolant flow diagram
    By got psi in forum Forced Induction
    Last Post: 10-30-2013, 12:45 AM
  3. M52tu coolant flow diagram
    By Jesus Freak in forum 1996 - 2003 (E39)
    Last Post: 02-09-2012, 11:30 PM
  4. Why does coolant flow through the Throttle Body?
    By Thin Air in forum 1991 - 1999 (E36)
    Last Post: 11-28-2003, 11:13 PM
  5. Coolant flow problem! help!
    By jb325 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-22-2002, 02:46 PM
