Results 1 to 11 of 11
Thread: final drive/diff cooling
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Was just reading in a German language Alpina brochure for E36 parts that they have/had a special version diff cover for better cooling, translated: Alpina final drive cover
    To keep the oil temperature in the final drive of the BMW Alpina B8 4.6 in the acceptable area, a special diff cover was designed, which offers a larger surface with 19 cooling ribs. The oil volume was increased to 3.1 liters with this design.
    A oil temperature reduction of up to 30 degree Celsius can be achieved.
    This modification is especially recommended for your BMW when you drive often higher speeds on the Autobahn over long distances, and also for cars which are used for pulling trailers. For BMW 323i - 328i, M3 up to 9/95; Touring, Cabrio,
    order/part no. 33 10 131, brochure print date September 2003, pic on page 5 of the catalog https://www.thealpinaregister.com/do...lpinaparts.pdf
    Unfortunately it does not fit my 1998 M3.
    Are there any other companies which offer such diff cooling mods for the E36?
    Jul 2015
    Walnut Creek, CA
    None so far
    Rogue engineering! They make a beautiful finned diff cover which is almost identical to the Alpina for 650. They can also put in their urethane bushings for a bit more. I want to get one but need to buy a clutch first.
    Last I remember, rogue doesn't have them in stock and they're being made, but diffsonline should have them in stock.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Rogue used to offer a finned diff cover for the E36 188mm. Might have been another or a knockoff.
    Jan 2005
    Japan
    nice, looks like the Alpina one https://www.rogueengineering.com/Rog...over_p_75.html
    excerpt from description: The benefit of this expanded capacity cover is to extend the life of the LSD clutch packs. These clutch packs will overheat when driven at the limit. Our cover helps reduce the temperature in a number of ways:
    1.Increase fluid capacity from 1.5 quarts to 3 quarts.
    2.Extended "fins" catch airflow to cool the cover itself, as it heats up from the increase in fluid temperature.
    What happens when you use a stock differential at the track, even at a simple driver school? With a single 30 minute track session, a driver with average ability can increase the temperatures in a stock differential, causing the fluid to start seeping out of the vent hole. By doubling the capacity of the amount of differential fluid, as well as adding much needed cooling fins, the differential is allowed to function properly, within the factory specified temperature parameters. The cooling fins stick below the actual differential, allowing for additional cooling. For increased cooling surface area, the fins are connected at the bottom, similar to the factory E39 M5 and E46 M3 differential covers. The extended area of the differential cover extends 2.25" lower the stock cover.
    How Effective Is the Cover? In a recent AER race, a team running an E36 logged data on their E36 during the 9 hour event. They reported back to us they found a 35 degree F drop in differential fluid temperatures. By reducing these temperatures, they are able to prevent their differential from a necessary rebuild from overheating.
    The Netherlands
    DE-spec E36 328i/M3 cab
    Yup, Alpina only made one for the 188 diff.
    I doubt you could get the 210 diff too hot that easily.
    IG:
    Jun 2005
    New England
    We had a 79 Euro 635csi that had a 210 diff with external cooler. Not sure whether it was original or aftermarket since I don’t know the exact history of the car. It was seriously modded and tracked.
    Jun 2010
    NY
    1997 328i
    That RE part is badass and worth it for people who race.
    We need china to make one for all of our diffs, they would be like $100 lol.
    Jan 2019
    HK
    Would this only be useful for differentials with clutch packs ?
    Jan 2005
    Japan
    see RE details: The benefit of this expanded capacity cover is to extend the life of the LSD clutch packs. These clutch packs will overheat when driven at the limit.
    So basically as also Alpina says: driving at the limit/high speed on the Autobahn over long distances or when hauling, races, not needed for daily use.
    The Netherlands
    If your just hauling on the Autobahn, there will be little to zero action on the clutchpacks.
    IG:
    Jan 2005
    Japan
    You are from Europe and you know how many cars there have tow hooks and in summer time there are plenty of people using it to haul large campers + drive thru the Alps and they often use the steep scenic Alpen streets instead of the Autobahn tunnels.
  1. Final drive oil cooling line, replacement.
    By fstenb in forum 8 Series (E31)
    Last Post: 05-28-2014, 04:30 AM
  2. FS: E34, E32, E31 diff (final drive) 2.93 open
    By 540i6Mike in forum BMW Parts For Sale
    Last Post: 02-12-2007, 03:50 PM
  3. "Clunk" noise form the final drive? (Diff)
    By Riaanc in forum 1992 - 1999 M3 (E36)
    Last Post: 08-31-2006, 01:40 AM
  4. 328 Diff / final drive question
    By propr`one in forum 1991 - 1999 (E36)
    Last Post: 03-23-2006, 09:37 AM
  5. new diff or final drive?
    By el_bobbo in forum 1992 - 1999 M3 (E36)
    Last Post: 12-15-2005, 10:20 AM
