RM European Auto Parts
Results 1 to 9 of 9
Thread: Wire caught under cylinder head
    Aug 2018
    Watsonville
    97 M3, 97 328i, 95 318ti
    Boi, you guys aren’t gonna believe this.
    So i got my car back from the mechanic. he did a headgasket replacement. i trailer it home, and i rolled off the trailer, thank god i didnt turn the thing on. i looked around and saw a wire kinda dangling so i went to get it out the of way and found it snagged. i checked where it was snagged and guess what??? it was squashed underneath the cylinder head at the part where the thermostat canals are. i was so pissed and now don’t know what to do. so should i run it and see if it will hold compression, the head sits flush with the block and everything looks sealed? I spent $950 on this replacement because it was a old friend and he hooked it up, but i dont wanna take it back and spend more money if the issue can be resolved at home. if not then i guess ill spend more money, but i gotta hear from the pros about this one.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Take it back. The head's got to come off again.
    Chris Powell
    BMWCCA 274412
    Agreed. And you'll need a new set of head bolts (one time use). And I don't know that I would reuse that head gasket either.
    Aug 2018
    Watsonville
    so theres no way that squashed wire can hold compression? it is on the edge if the block not too much of it is snagged underneath the head.
    NW suburban Chicago
    hiss by my window
    between the head and block, really?!
    Do you maybe mean the valve cover?
    If so it's a re-do, w gaskets and bolts, inspect the head & block surfaces too.
    Jul 2004
    Houston, TX
    36 Cylinders
    I definitely want to see a pic.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jeez bro. If you're not going to take our advice, then don't ask for it. Clearly your mechanic did a crap job and screwed it up. You paid him for the repair that wasn't done up to standards. Either take it back and have him fix it, or take your chances with a botched repair. Old friend or not, he screwed up. I know what I would do.
    Jun 2002
    E39M5, E500 4WD
    Me too. This isn't even a question.
    Look, I have made a lot of mistakes, over the years. I've caught the O2 sensor wires in the valve cover gasket, and had to redo that job; 4 .5 hours. Last week, I lowered the lift with a Mini on it, and a jack handle poked a hole through the lower valence. $200 which I paid for, because it was my own very stupid mistake.
    $#!+ happens; the mechanics needs to fix his mistake, with a new set of head bolts and a new gasket. The guy made a huge mistake, and it's completely his fault.
    You have two master techs telling you that they would absolutely have to fix their mistake. There's no other answer, period.
    Chris Powell
    BMWCCA 274412
    Jan 2016
    Ca
    2001 525it
    Exactly who hasn't made mistakes while at work, everybody.
  1. Second ground wire from coil to cylinder head not connected
    By ffkk in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-11-2011, 10:26 PM
  2. Cleaning engine block/pistons, under the cylinder head
    By DamianJP in forum 1983 - 1991 (E30)
    Last Post: 03-01-2011, 12:12 PM
  3. How to wire amp, with stock head unit
    By Shawn323iC in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-23-2007, 11:31 PM
  4. Blown Cylinder Head Gasket
    By neaks325i in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-21-2002, 04:04 PM
  5. WTB: Used 93-95 325i or M3 Cylinder head
    By Jesse325i in forum BMW Parts Wanted
    Last Post: 03-29-2002, 12:24 AM
