Results 1 to 4 of 4
Thread: Can you crank the engine with a button and alligator clips?
    Apr 2016
    Heinderson, NV
    1998 328i BMW
    E36: 1998 328i
    There was a time when you could just put a lead on the starter solenoid and the other on positive and then press a button to crank the car.
    I don't see myself getting a lead down to the solenoid without taking a few parts off the car so I went looking for how to do this and the only thing I found was one suggestion to use pin 11 on the diagnostics plug but mine has no pin 11 so that's not going to work.
    Is there a way to do this without performing backflips or should I just resign myself to using the key in the ignition?
    Oct 2013
    The Netherlands
    2011 E90 325xi
    I think with your year you’ll need the key anyways (due to ews)
    Nov 2013
    Oneida, NY
    1993 318is/who to knows
    Sure can. Jump the 2 big wires at the ews module, attach momentary button to the ignition switch black and yellow and red. Boom. Crank away.
    Nobody would recertify these machines after somebody screwed with them without any visibility into what they did.
    HONK! HONK! Clown car coming through!
    -Oakdizzle
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I have a recollection of using a momentary switch to bump the starter entirely from under the hood. Obviously with shifter in neutral. Can’t recall whether I had the ignition on or not.
  1. How bad is cranking the engine with no start?
    By 530e39 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-29-2012, 01:46 PM
  2. Long Cranking before Engine Starts
    By Perrier in forum 2004-2010 (E60,E61)
    Last Post: 07-10-2010, 11:19 AM
  3. Who installed Engine Start/ Stop button in E38?
    By djafar740d in forum 1995 - 2001 (E38)
    Last Post: 06-10-2010, 04:27 PM
  4. Replies: 14
    Last Post: 04-10-2010, 02:35 AM
  5. Replies: 5
    Last Post: 02-18-2006, 01:20 PM
