Results 1 to 11 of 11
Thread: E39 Abs fault
    Mar 2019
    Ireland
    BMW E39 530D
    E39 Abs fault
    So I have the dreaded abs fault in my 530d
    Previously I had lights on the dash but I replaced the abs sensor passenger side. Built the car back up took it a run and the ABS is kicking in constantly but no lights on the dash. Then when you stop and leave the car idling the abs light comes on.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Scan for codes.... Sensor? Module? Who knows with out a scan.. Its all internet guesses otherwise.
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Oct 2005
    Silver Spring, MD
    Too many
    My 99 E39 touring exhibits the same symptoms. The module has been confirmed bad as is probably the case with your car. In my case the module cannot be repaired so I have to replace it, but in my experience this is a somewhat unusual situation. Unfortunately module failures don't always result in a fault code being generated so the actual issue can be somewhat difficult to diagnose.
    Sent from my SM-T597V using Tapatalk
    00 740iS
    84 635 (euro)
    88 M6
    84 745i
    88 325iX
    92 850i (6 spd)
    Mar 2019
    Ireland
    BMW E39 530D
    Sorry should have noted there is no codes on the car now when driving.. When you leave it to idle the code is for p/s front abs sensor which I've already replaced. Who repairs the abs units?
    Oct 2017
    Beaverton, Oregon, USA
    2001 E39 540i A, 207 k
    So, what reader did you use to read the error codes ?
    If the ABS light comes on, it leaves an error code. What is it ?
    Mar 2019
    Ireland
    BMW E39 530D
    I used inpa to read the codes. When the light came back OK the code was again stored for front left hand abs sensor. Sorry for the confusion
    Oct 2017
    Well, then you have a defective ABS sensor, on the front left side of the car. Did you install an oem abs sensor ? or a cheap after-market one??
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Repair
    BBA Remanufacturing Inc
    300 Myles Standish Blvd
    Taunton, MA 02780
    United States
    1 508 822 4490
    Fax 1 508 822 4491
    us-sales@bba-reman.com
    Website: www.bba-reman.com
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    Jan 2015
    Shreveport Louisiana
    try swapping the front sensors left <->right and see if the problem follows. if it does, its the sensor. if it doesnt, but stays on the same side, its either the chassis harness or the module.
    Nov 2018
    La Habra, CA
    2002 525i
    Concerning module repair, I just recently used Module Repair Pro in Van Nuys, CA. I had the trifecta, and the code showed ABS Sensor Open Circuit, FWIW. For $99, plus shipping, they rebuilt it and all the codes went away immediately after installation. ABS works fine and I'm really pleased.
    Oct 2005
    Silver Spring, MD
    Too many
    Plus one for BBA Remanufacturing. I recently sent my module to them for repair. They called to let me know that they weren't able to repair the unit. I was offered the option of purchasing a replacement unit from them, or having my unit replaced and my money returned.
    I thought that was a very honorable offer to make. I'll definitely use them again if the need arises.
    00 740iS
    84 635 (euro)
    88 M6
    84 745i
    88 325iX
    92 850i (6 spd)
  1. E39 ABS fault
    By ra1994gh in forum 1996 - 2003 (E39)
    Last Post: 06-09-2016, 08:27 PM
  2. BMW E39 ASC/ABS fault codes # 66,67
    By Elshadstyle in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-05-2015, 06:41 AM
  3. 1999 E39 Internittent fault: Speedo not working & ABS+ASC warning lights on.
    By Davepeers in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-02-2015, 10:03 AM
  4. E39 E39 ABS Module
    By VFTS in forum Brake Kits, Rotors & Pads
    Last Post: 01-19-2013, 12:35 AM
  5. E39 E39 ABS Module and ABS Pump - $300 Free Next Day Shipping
    By 5FortyI in forum Engines, Performance Parts & Software
    Last Post: 05-27-2009, 06:50 PM
