Results 1 to 6 of 6
Thread: M73N: MAF plug & Play? Maybe not...
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    TLDR: anyone else find that you have to do a “reset” (KP2 for 30 seconds till TB clicks) for a MAF replacement?
    Vehicle: 2001 750iL
    Miles: 131K
    Symptoms:
    • light rough idle
    • Bank 2 P0100 MAF voltage value exceeded
    • loss of cruise control when code active
    • All the misfire with cutoff codes possible for Bank 2
    Action taken: replaced Bank 2 MAF with Bosch OEM part
    After replacing the one MAF for Bank 2, I still had an idle issue. It would surge to 1000 and drop to 450. Any load and it was fine, smooth as butter.
    Coming to a stop and idling though and idle hunt with an occasional stall for good measure.
    Thinking “bad MAF?” And hoping not as they are expensive and old/new situations were both bad, I wanted to explore what else could be done.
    Back in the E39 days, a simple throttle body reset (KP2 for 30 seconds till the TB cycled, key out, then start) actually resolved a bunch of issues. Not knowing if this was applicable, and thinking MAFs were plug and play, I tried it.
    Sure enough, smooth idle and no more issues.
    Maybe with the dual MAF, the DMEs need to synch the TB and base MAF numbers for equal torque?
    Anybody else experience this?
    2001 750iL DD74441
    Stock
    RIP: 2003 540iA Sport GS56111
    H&R front springs, Ultimate Cup Holder, Euro Dash & Armrest, Grom, BavSound Stage1
    Nov 2016
    Hansville, wa
    2001 750il Chrome line
    Not a 750 guy but I think I remember reading you have to do both MAF's? Make sure you do a smoke test for vacuum leaks before you drop another $400 on a MAF>
    01' 750il Chromeline
    95 M3 LS swapped
    07 M5 Manual
    06' M5, Spartan wheels and a 507hp V10
    00' 740il Dinan, CAI, Romulus exhaust, Stage 5 engine and transmission tune, 750 brakes, camber plates, strut tower brace. Sold
    00' 323i wagon for daughter
    03' 525i wagon for the wife, sold
    98' 740i for the daughter, wrecked
    92' 525i with over 200k, wrecked
    02' R1200 CLC, hit by a bus and broken in half. That one made the news!
    It's like herpes there is no cure but if treated properly you can live with it for the rest of your life
    Jul 2015
    Dallas, Texas
    98 750iL, 01 740iL
    looks to be pointing to your throttles
    Dec 2016
    Springfield, VA
    2001 750iL DD74441
    Quote Originally Posted by acspecialists View Post
    Good idea. Not outside of range (no SES/code on that) but will check trims and if 5% or more do that.
    Quote Originally Posted by MKIVJZA80 View Post
    Found the full reset procedure from Mayorchuck and DUMD and seemed to work even better.
    And for public knowledge
    KP2 for 3-5 seconds
    Accelerator to kick down 3-5 seconds
    Release accelerator for 3-5 seconds
    Accelerator to kick down for 3-5 seconds
    Release for 3-5 seconds
    Key out for at least 10 seconds
    2001 750iL DD74441
    Stock
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Yes, I remember having to do this
    Apr 2014
    PA
    Just fyi, M44 MAFs are the same as m73 mafs. I have 2 junkyard 318 m44 mafs currently on my m73. I had a horrible idle problem and surging at speed. Had a MAF code stored for both units weirdly enough. Changed both with the used m44 mafs and performed a throttle sync for giggles. Woke the car right up and fixed all issues. Been fine for last 400 or so miles.
    "Helicopters: 10,0000 pieces of metal fatigue rotating around an oil leak."
  1. Replies: 4
    Last Post: 02-04-2017, 04:32 PM
  2. Is Bosh 803 Porsche MAF plug n play??
    By BMW325issport in forum 1992 - 1999 M3 (E36)
    Last Post: 08-21-2013, 12:05 AM
  3. Is Bosh 803 Porsche MAF plug n play??
    By BMW325issport in forum 1991 - 1999 (E36)
    Last Post: 08-19-2013, 05:42 PM
  4. Replies: 4
    Last Post: 04-23-2013, 09:02 AM
  5. will a non vanos maf plug and play with vanos?
    By squeezeandgo in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-06-2008, 02:59 PM
