Results 1 to 2 of 2
Thread: Would the rear exterior door-handle trim from a sedan work on convertible?
    Oct 2008
    Coos Bay Oregon
    09/95' 325ic
    I recently replaced the passenger door handle on my E36 Convertible. I failed swapping the key cylinder from the old handle to the new (long story). I ended up having to drill out and remove the cylinder so now the handle has a hole where a key cylinder should be. Since the trim around rear door handles on sedans don't have holes for key cylinders I thought it might cover the key/cylinder hole in the passenger side of my car.
    My guess is the sedans have smaller handles and ultimately smaller or incompatible trim. But I figured it was worth asking before I spend money to place an order for something I might never use.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Rear door outer trim door handles have same length, I just compared the gaskets I am selling for the outer door handle trim for front and rear. here I posted a pic https://www.bimmerforums.com/forum/s...de-door-handle
    Might work as you are planning.
  1. Replies: 2
    Last Post: 12-15-2005, 02:02 AM
  2. Replies: 2
    Last Post: 07-07-2005, 04:04 PM
  3. Exterior Door Handle Trim
    By uuc328 in forum 1991 - 1999 (E36)
    Last Post: 12-29-2004, 08:34 PM
  4. Exterior Door Handle Trim Problem.
    By BIMMERLOVR in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-18-2004, 01:59 AM
  5. Installing Exterior Door Handle Trim (Front Passenger Side)
    By tenick in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-11-2004, 12:58 PM
