Results 1 to 4 of 4
Thread: 5 to 6 speed swap?
    Aug 2018
    SoCal
    2004 BMW E46 325ci
    5 to 6 speed swap?
    I have an 04 325ci e46 vert and I want to know if anyone has ever 5 speed to 6 speed zf swapped their car? I want to get rid of the getrag. Is it easy and similar to do such as the e36, or will there be a whole compatibility issue, and will I have to recode the dme? Thanks.
    Apr 2015
    Netherlands
    2000 E46 328i
    There is no need to recode anything, thats for sure. On the mechanical side I'm sure someone here can answer if it bolts right in or there's more to it
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Beside the driveshaft, shift linkage, should be pretty straight forward. I would also think that it would be a good idea to replace the clutch with a single mass flywheel, as those dual mass tend to wear out quickly.
    I have been on the hunt for a 6-speed for a bit now for the wagon, love to get one in there.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Aug 2009
    Houston,Texas
    83 533 92 325 97 m3
    Doing a ZF 6spd swap for someone and he had the trans and flywheel and clutch kit but I need to get the bracket for the back of the trans and either mod the shift console bracket or get it from zionville. Anyone know if you can buy a shift linkage or is it a mod only say cut 1 1/2 inches off the zf 6 speed linkage. and what shifter should I use. In my 5 speeds I use a 1.9 Z3 and bend them they work great but with the 6spd the guibo is really close to all that. Im doing a second after this one so need my duckys in a row for that one.
    Jimmie
  1. 6 speed swap!
    By robbie in forum 1995 - 2001 (E38)
    Last Post: 12-11-2004, 11:45 PM
  2. Anyone interested in a 5-Speed swap?
    By BMWg84 in forum 1991 - 1999 (E36)
    Last Post: 01-15-2004, 03:37 AM
  3. 6 speed swap?
    By Jeepin_Lawyer in forum 1991 - 1999 (E36)
    Last Post: 05-01-2003, 07:07 PM
  4. 5 speed swap.....
    By Shoe Coupe in forum 1991 - 1999 (E36)
    Last Post: 03-25-2003, 03:41 AM
  5. Anyone have experience with e34 slushbox-5 speed swap?
    By Ben Carufel in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-05-2002, 10:43 PM
