Results 1 to 7 of 7
Thread: Confused over Getrag model
    Apr 2018
    Australia
    96 318i E36,99 318is E36
    I'm doing an engine swap on my 99 318is and I have 2 options to consider for a manual transmission - 1. What was already in it, running off the 4 cyl, or 2. Whatever is in my 93 320i. They're both Getrags, both 5sp, but I'm unsure what particular model either of them are.
    Off the 318i coupe the number on the side of the transmission is 220.0.0225.98 ( has 220.0.0223.94 on the rear of the transmission though ? ).
    Off the 320i transmission it has 220.0.0225.96.
    Now I couldn't find much if any information with those numbers to be sure what they are, or which of the 2 is better. What I think I've found is the one off the 320i is a Getrag 240, and the one off the coupe could be a 220 or a 250 but this is based off just one commenter on some forum so I can't be sure.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Let us know the VIN, then it might be easier to search
    Jun 2016
    California
    E36 325is
    Not to hijack at all, but I have also noticed some differences between the two Getrag G260's that I have, both came from 325is's. One from my 95 and one from a 93. The linkage is different, and there are a few other small discrepancies. I have run both...
    Apr 2018
    Australia
    Quote Originally Posted by shogun View Post
    let us know the vin, then it might be easier to search
    coupe vin: eu11582
    320 vin : al53154
    I've managed to find what I was looking for on a site called bimmercat. com. It says it's a Getrag 250, though surprisingly, for both the '93 and '99. I would have thought over 6 years there would be some improvements made between them.
    So unless I'm wrong, it seems I just have to pick the best out of what I have. Time to do some research on the 250G.
    Cheers.
    Jan 2005
    Japan
    http://www.realoem.com/bmw/enUS/part...&q=23007505600
    https://books.google.co.jp/books?id=...20250G&f=false
    http://workshopmanual.com/files/38/pdf/page-569.pdf
    http://workshopmanual.com/files/38/pdf/page-569.pdf BMW S5D 250G = Getrag B transmission (220/5) reinforced version
    that is all I could find, now up to the Getrag experts to deliver more info
    Apr 2018
    Australia
    Excellent, thanks shogun for the links.
    Jun 2016
    California
    E36 325is
    I mean, pick between the two, then replace the input shaft seal and bearing on that one... you know you made the right choice.
  1. Confused about e39 models? newer ones are slower??
    By nero11 in forum 1996 - 2003 (E39)
    Last Post: 09-20-2013, 03:32 PM
  2. Confused... Early/Late model headlight interchangeability...?
    By BMWTurbo in forum 1988 - 1994 (E32)
    Last Post: 05-06-2010, 07:26 PM
  3. Newbie confused by all the different models, pls help.
    By kevinsky18 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-15-2007, 01:57 AM
  4. Im confused about these e92 models
    By Le Nitro in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 10-29-2006, 04:01 PM
  5. My BMW Model???Confused
    By fooshe2000 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-19-2005, 01:06 PM
