Results 1 to 12 of 12
Thread: Anyone uses Liqui Molly 10w60?
    Sep 2017
    Northeast
    2001 M Roadster
    I am typically put Castrol TWS 10w60 into my almost 60K S54 engine. I found a mechanic to do some work on the motor (rod bearings). He is a bimmer guy too and tracks his cars. He swears by Liqui Molly 10w60. Just curious if anyone using it in our engines? My car is mainly used for pleasure, but some performance driving school action too.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Does it really matter what oil is used? When I bought my used Z3 from a dealer, he changed the oil with BMW mineral 15W-40. After that I have been using Mobil 1 0W-40. In 15 years of forums for three very different cars, I have never heard of any oil-related problem. All the engines run fine until they run out of oil.
    BMW MOA 696, BMW CCA 1405
    Feb 2014
    Galt,CA
    2002 M Coupe
    If you're running an S54, oil is much more critical. There were very specific requirements due to the RPM and rod bearing design. The Castrol TWS 10w60 allegedly met all of them. The specs for most other 10w60 oils are different. I'm not conversant enough to know what issues are critical, so I've stuck with the Castrol in my S54, which doesn't consume any oil at 104K miles, and the original rod bearing were in good condition when I replaced them recently. Hopefully someone who has actually used an alternate oil will check in with their experience.
    Marty
    Sep 2017
    Northeast
    2001 M Roadster
    Quote Originally Posted by Vintage42 View Post
    Does it really matter what oil is used? When I bought my used Z3 from a dealer, he changed the oil with BMW mineral 15W-40. After that I have been using Mobil 0W-40. In 15 years of forums for three very different cars, I have never heard of any oil-related problem. All the engines run fine until they run out of oil.
    I am going to let Randy and alike to argue about oil quality. I guess it could be olive oil as long as it keeps its viscosity. As non-mechanic, I have to rely on google university and this forum to select what mostly recommended by the pros in business. I believe the argument here is, when you open up an engine and it looks like new, you used quality oil. The opposite of the spectrum is all brown burned sludge... I believe Randy Forbes talked about that in one of the posts that I can not find at the moment.
    Oct 2012
    Louisville, KY
    Quote Originally Posted by DimrBimmer View Post
    ... oil quality. I guess it could be olive oil as long as it keeps its viscosity...
    So quickly an oil thread has devolved to olive oil ;-)
    Sep 2017
    Northeast
    2001 M Roadster
    Could have been worse, Peanut oil. Although peanut oil does have higher smoke point.
    Dec 2007
    Great Dismal Swamp
    E36/7 E36/8x2 E46 F25
    Peanut oil is much more preferable to olive oil. This is based on highly selective back to back google searches.
    (Full disclosure, I live in the self-proclaimed peanut capital of the world)
    I stock the LM- 10W60. I used it in my own boosted S52 until I installed an oil-cooler. No complaints.
    /.randy
    Basking Ridge, NJ
    2001 BMW Z3 2.5i
    I've run the LM 10w-60 in my Moto Guzzis for years and it does a great job. Will be using it in my 2.5i at the next change. BMW calls for this weight and that it's synthetic. I suspect the engineers know more than me so I follow the manual and use the 10w-60.
    And don't trust dealers to know or give a crap. When I bought my first Guzzi they had filled the engine with 10W-30 dino juice since the service thought 'it's all the same stuff'. Almost ruined the engine before I even got it home.
    It's not the years in your life that counts, it the life in your years...
    Ive run it on S54 and S62s for awhile... No problems. Pretty long history of e46 m3 guys using it
    PRICE CUT on ALL FABRICS
    Fort Worth, TX
    E36M3/E46M3/E39M5/E63M6
    LM RT GT1 10w60 is a fine oil to use in S54. Have been running it in 3 of my E46Ms, my E39 M5, and my E63 M6. No problems thus far. Oil consumption in my S85 decreased from about a quart per 1500 miles to about a quart every 2000 miles after switching to LM from Castrol.
    Blackstone reports continue to be stellar, though, at the end of the cycle (I usually go about 7-7500 miles on oil) viscosity numbers are slightly lower with LM, but not significantly so and still within acceptable range. Overall, for the price, I'm sticking with it until I find something better.
    E36/8 2000 M Coupe Cosmos Black/Black
    Shark, Conforti CAI, B&B Exhaust, H&R, Bilstein, AKG Subframe/Diff, UUC TME Red/Caps, Swapped Front Hats, Ice>Link.
    Tim @ BMW of Dallas
    98 Z3 2.8
    I use the LM 10w60 in my father's 01 S54. Has around ~150k on original rod bearings with no issues. Been using the LM since about 85k. Another local group member uses the LM in his 02 S54, no issues. Not sure on mileage since he's on his 3rd engine... Nothing LM or oil related though. (hydro-lock)
    96 320i Touring
    98 Z3 2.8 Roadster
    01 PY M Coupe
    96 Z3 1.9 - DASC
    95 318ti Clubsport
    94 Miata M-Edition
    13 smart fortwo
    Sep 2017
    Northeast
    2001 M Roadster
    Thank you all!
    I guess I don’t need to fight my mechanic on oil choice.
  1. Has anyone ever used the Lubrimoly 10w60 on their S54?
    By buhx2 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-21-2007, 01:39 PM
  2. Does anyone use "Race Glaze" polish and sealant?
    By Bob ///M3 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-27-2001, 01:34 PM
  3. anyone use MASHAW products for our cars?
    By Josh///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-17-2001, 12:37 AM
  4. Anyone uses V-1 in Northern VA/DC area?
    By vroo//M in forum 1992 - 1999 M3 (E36)
    Last Post: 03-23-2001, 10:35 AM
  5. Anyone uses V-1 in Northern VA/DC area?
    By vroo//M in forum 1991 - 1999 (E36)
