Results 1 to 3 of 3
Thread: Cam Position Sensor
    Parsippany, NJ
    1998 M Roadster, '01 A8
    Cam Position Sensor
    I had an adventure with a failed vehicle inspection. The cam position sensor code came up. My garage installed a new one. The fault didn't clear. He installed another sensor. No joy, but suggested maybe the VANOS was tired after 20 years and 122K miles.
    Vanos was replaced but fault remained. It was determined by second mechanic that the replaced sensor was not OEM. An OEM sensor was installed and the fault went away and the Roadster passed inspection. Beware none OEM sensors.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Non-OEM problems are common knowledge. But it would be interesting to know the brand of the first sensor, and that of the second sensor. Because they could both be the same.
    There is an ongoing question among such threads here as to whether the quality of the same brand is better if bought through the BMW parts system with BMW stickers on the box.
    BMW MOA 696, BMW CCA 1405
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by Vintage42 View Post
    VDO or Semens sensors should have been good, were they either?
  1. cam position sensor wire problem
    By andylv in forum 1992 - 1999 M3 (E36)
    Last Post: 09-01-2005, 11:16 PM
  2. Cam Position Sensor
    By ae86_16v in forum 1991 - 1999 (E36)
    Last Post: 03-11-2004, 10:53 AM
  3. Help! - Cam position sensor problem
    By red740is in forum 1995 - 2001 (E38)
    Last Post: 02-23-2004, 04:23 PM
  4. ever replace a cam position sensor?
    By Jasonb1971 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-18-2004, 08:14 PM
  5. Cam Position Sensor Recall?
    By BabyM in forum 1991 - 1999 (E36)
    Last Post: 01-27-2004, 11:25 PM
