Results 1 to 8 of 8
Thread: Driver's Side Oil Leak
    Aug 2013
    1999 BMW M3 Coupe
    I noticed recently that I still seem to have a small oil leak even after addressing the valve cover and oil pan. This time it appears to be originating from somewhere on the driver's side of the block, as I see oil/wetness on the block just forward of and around where the motor mount arm bolts to the block. Where are the common places it can leak from on this side?
    My first thought is the oil filter housing, but that's a ways forward and I'm not sure how the oil would find its way back there. From above peeking down with a light I can't see anything obvious on the filter housing, but I can't see the full underside. What other oil plumbing sits under the intake manifold there other than the CCV (which I guess could also be the culprit)?
    Oct 2003
    Seattle
    99 M3
    Ya, I would guess the oil filter housing gasket or VaNos line fitting to hose crimps.
    Feb 2009
    Mills River, NC
    95 M3 coupe, 97 M3 sedan
    Apart from the oil filter housing to block gasket, on the back of the filter housing there are 2 o-ring seals that can leak, plus the VANOS oil line. You'll probably need a mirror and a flashlight to check the o-ring seals.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    How old is your CCV? I'd be willing to get that's it or something associated (hoses, o-ring, install, etc). When my oil filter housing was leaking it made it's way back on the block, but not so far back that it was by the motor mount.
    Aug 2013
    1999 BMW M3 Coupe
    Ok, guess it's probably just time to stop slacking and do my M50 manifold install, and fix whatever's leaking at the same time. After shining a light in there some more yesterday I'm fairly confident that it's coming from the gasket between the filter housing and block, and then flowing down/back from there. I'll probably plan on just doing the filter housing at the same time as well, replacing all the gaskets/seals.
    My CCV is probably only like 8 years old I think, though I do have a brand spanking new one sitting around which I may throw in at the next opportunity.
    KC
    1995 M3 & 1998 M3 coupes
    Mine was definitely due to the oil filter housing gasket. Total pain to replace for such a little gasket, but so nice that it no longer leaks!
    John
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Quote Originally Posted by TostitoBandito View Post
    Might as well refresh any vacuum or coolant hoses while you're there so you don't have to again for a very long time.
    Quote Originally Posted by E85STI View Post
    John
    I didn't find it too bad, but it's also way easier with the manifold out of the way. Just have to remove the alternator if I remember correctly
    Durham, NC
    2x 97 M3/4, 05 530i
    The filter housing is so big and touches so many things that oil from that gasket can get EVERYWHERE on the drivers side. If you are having a drivers side oil leak and have never touched that gasket there's no reason to even look any farther until you replace it. It will get all the way down and drip off the front subframe.
    It's not too bad to replace, honestly. If you've had your clutch fan off recently the rest goes pretty quick. But I've never seen any bmw from the e36/e39/e46 era that didn't have a filter housing gasket leak. I keep 4 or 5 of them in my garage for whenever a friend comes by to do anything. They are THAT bad.
  1. Power Steering Sticking & Large Passenger Side Oil Leak
    By imagin3peace in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-07-2016, 04:30 PM
  2. Power Steering Sticking & Large Passenger Side Oil Leak?
    By imagin3peace in forum 1983 - 1991 (E30)
    Last Post: 05-06-2016, 12:23 PM
  3. Drivers side oil leak?
    By Blakex2212 in forum 1991 - 1999 (E36)
    Last Post: 11-10-2013, 03:08 PM
  4. M44 oil leak drivers side
    By Albertan in forum 1991 - 1999 (E36)
    Last Post: 08-01-2011, 03:00 PM
  5. Phantom driver's side column leak
    By new2beemer in forum 1995 - 2001 (E38)
    Last Post: 09-05-2007, 01:14 PM
