I have an RMS Supercharger kit for an E36 I would love to sell, however the aftercooler setup has been sold.
I bought it 4 or 5 years ago from the original owner, installed on a car but never finished the project and its been sitting since. I had it running a few months ago on the tune included in this sale, it was awesome but the car needs a ton of work in other areas and I have decided to part it.
Original owner sold the kit in favor of an engine swap, Supercharger was rebuilt by vortech 800 miles before his motor blew....I may be able to dig up the paperwork.
The kit includes:
RMS Supercharger kit with brackets and all your pulleys.
- Vortech V2 SC Blower - Polished
- RMS 8Rib Pulley Setup 7.5" Crank Pulley 3.65" supercharger pulley - I believe this pulley combo nearly maxes out this blowers rated rpm at 7200rpm
- All bolts and brackets needed to bolt the blower and pulley on
- Drive belt in decent shape
- Silicone couplers and t-bolt clamps for inlet tube
- Metal fabricated inlet tube for supercharger ?RMS?
- RMS Long Tube Headers, Used with some minor pitting coming through the coating
- 803 MAF and pigtail
- 42/lb fuel injectors
- OBD1 ECU for a 3L with RMS tune ....Please do not use the tune, its not great but will get you started. Id run an aftermarket unit.
- Supercharger oil feed line with adapter fitting for the vanos bolt.
**Drain fitting is on the supercharger but you will need to tap your pan and source an oil drain line**
There you have it, a bolt on kit for anyone that wants to add a little more power to your m50 power plant. 2000 or make me an offer, I can ship it but its going to likely cost a few hundred.
SOLD
Aftercooler setup sold.
Any knowledge on how much trouble would be to run on obd2 S52?
$2000 shipped for the setup with no aftercooler
Washedit1 by thedude60526, on Flickr11/10's Racing
94 325i #36/64 TEAM PENISTON OILS/ LARSENS BISCUITS
Bump! Great seller - fast shipping and great packaging! (I got the after-cooler setup =D )
Sold
