Results 1 to 5 of 5
Thread: 21.5 lb Pink top injectors on m50 (with tune)
    Apr 2016
    Myrtle Beach, SC
    1994 BMW E34 525i
    Is it possible to use 21.5 lb injectors on a m50 that used green top 17 lb injectors. I also have a turner motorsport tune. If so what should I expect out of it.
    FL
    are slow.
    Does your tune specify that you use a 21.5lb injector? I'm not aware of any Turner Motorsport tune for an M50 that uses 21.5lb injectors.
    Just tossing in a larger injector is going to make it run rich and not well.
    -Dr. Seuss
    Apr 2016
    Myrtle Beach, SC
    1994 BMW E34 525i
    Im not sure. Probably not. I was just curious because I found some pink top injectors for cheap.
    Florida
    '87 325is 24v turbo buil
    are 21.5lb injectors going to really support any real boost?
    FL
    are slow.
    Quote Originally Posted by SS Ball3r View Post
    Sure. But even at 90% duty cycle you can't go above 200whp without going lean. 21.5 injectors are fine for a stock or slightly modified S52, but for forced induction you'll want a much larger injector. 40lbs+.
    -Dr. Seuss
  1. 6- 21.5 lb Pink Top Injectors
    By RomoGuy in forum Engines, Performance Parts & Software
    Last Post: 01-08-2014, 12:07 AM
  2. E36 E36 OBD1. 540i HFM maf, 21.5 pink top injectors, 413 DME with tune
    By hakentt in forum Engines, Performance Parts & Software
    Last Post: 01-08-2012, 03:32 PM
  3. E36 FS : 21.5 lb Pink Top Injectors
    By M3ZT in forum Engines, Performance Parts & Software
    Last Post: 06-02-2010, 10:11 PM
  4. 21.5 lb. Pink Top injectors
    By Spulen81 in forum Engines, Performance Parts & Software
    Last Post: 03-07-2008, 10:28 AM
  5. 540i HFM and 21.5# (pink top) injectors for sale...
    By Ryan Stewart in forum BMW Parts For Sale
    Last Post: 08-29-2006, 06:21 PM
