Is it possible to use 21.5 lb injectors on a m50 that used green top 17 lb injectors. I also have a turner motorsport tune. If so what should I expect out of it.
Does your tune specify that you use a 21.5lb injector? I'm not aware of any Turner Motorsport tune for an M50 that uses 21.5lb injectors.
Just tossing in a larger injector is going to make it run rich and not well.
-Dr. Seuss
Im not sure. Probably not. I was just curious because I found some pink top injectors for cheap.
are 21.5lb injectors going to really support any real boost?
-Dr. Seuss
