Hello bros, i have a problem with my car for a while now and cannot find a fix for it so i am asking here if anybody had the same issue and fixed it. Sometimes when i start the car and turn the key to ignition i hear only a single click and no crancking and sometimes if i held the key in ignition position after the click for 5 seconds it crancks and start, whenever i hear a click i have to try several times till the car crancks and start. This issue is more to happen in hot days. Last time today when i started the car in the morning it starts normally drove it for 20 minutes and left it for a 90 minutes and when i tried tostart it again it made the same click and i had to try starting it many times in about 15 minutes till it starts. I have checked the battery and alternator also changed 2 starters with the same problem. Hope somebody help me to fix this problem
It could be the ignition switch going bad.
Should ignition switch throw a code on any reader or not ? As i dont have any codes
no, ignition switch won't throw a code.....
i'd check voltage at the switch when problem is occurring.
you could also go to starter and check for voltage there when the problem is occurring.
ignition switch would be easier to check but a successful test there wouldn't rule out problems further down the chain.
This does sound like bad contacts within the ignition switch.
BUT FWIW The E36 lock housings are notorious for the link between the key lock and the actual switch (which is on the opposite side of the column)twisting and eventually breaking.
@OP If turning the key feels different or there seems a very slight delay between the turning and the starter actuation this is quite likely your problem. Seen this (too)many times.
time for some testing and data gathering then....
