Results 1 to 5 of 5
Thread: Front Fog Light Fault
    Jan 2019
    Leicester, Uniter Kingdon
    1995 840ci
    Hi,
    I’m pretty much finished clearing issues with my 840 and should be putting into daily service next month.
    The only issue which I’ve still got with the car is a front fog light fault. I’ve checked fuses and bulbs to no avail.
    Ok closer inspection, it looks like the wiring at the bulb holder might be the culprit...
    https://imgur.com/gallery/QyVYWWl
    I’ve tried to get into the fitting to replace the section of damaged wire, but I can’t get past the green stuff which I guess seals the terminals from the elements. Does anyone know what my options are here?
    I’ve tried to source a replacement bulb holder, but I’ve not managed to find one online.
    Thanks in advance
    Nov 2008
    NYC
    91 850i-95 850csi- 94 85
    They do sell a new harness but it’s not cheap and I think a member here use to recondition old ones.
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    are you talking about the light strip in the bumper? If so, those aren’t fog lights (common misconception), they are flash-to-pass lights and in Europe they also double as additional high beam lights. The fog lights are in the pop-up light assemblies.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Jan 2019
    1995 840ci
    That’s interesting, thanks. I’ve not tested them to see if they work on Main Beam, so I’ll do that before I try replacing the bulb holder - perhaps just put some heat shrink over the exposed wire.
    I’ll take another look at the headlight pods for the fogs then, thanks. It may just be a failed bulb.
    Feb 2015
    Kuna, Idaho
    Too Many Cars (NOT!)
    Double check all your headlight wiring. There have been several instances of car fires due to destroyed headlight wiring. When I hearead about it, I checked mine and found this:20160911_145729.jpg20160911_150457.jpg
    I replaced it with a completely new harness provided by a member here.
    Mike Drives:
    BMW's
    E24 - 635CSiA - (1) 1985 (US)
    E24 - 635CSi - (1) 1985 (EC)
    E31 - 850iA - (1) 1991 (Black)
    E31 - 850iA - (1) 1991 (Calypso Red)
    E32 - 740iA - (1) 1994
    E32 - 750iA - (1) 1990 (Not an "L") (EC German National)
    E32 - 735iL - (2) 1990
    E32 - 750iL - (1) 1990
    E38 - 740iLA - (2) (1) 1997 & (1) 1998
    E38 - 750iLA - (1) 1998
    E38 - 740iA - (1) 2000 "Short Sport"
    E39 - 528iA - (2) - 2000 & (1) 1997
    Also:
    2015 Ram 3500 Dually, Cumins 6.7, Std.Cab. Long box 4x4 (To haul all this junk when necessary)
    2014 Dodge Dart Rallye (Daily Driver)
    2007 Mercedes Benz CL600 (Brabus SV12S)
    Mercedes Benz SL's - (1) (2002) & (1) 1999 500 - (1) 1999 600
    1967 Buick Riviera (2)
  1. E36 Front Fog Light
    By kemmish in forum BMW Parts Wanted
    Last Post: 03-01-2007, 04:31 PM
  2. Front Fog light wiring, have or have not?
    By stephford in forum 1991 - 1999 (E36)
    Last Post: 01-30-2007, 12:27 AM
  3. Wanted e36 front fog light
    By r.bot in forum BMW Parts Wanted
    Last Post: 01-26-2007, 05:34 PM
  4. Wanted: e36 front fog light
    By r.bot in forum BMW Cars For Sale / Wanted
    Last Post: 01-26-2007, 07:03 AM
  5. WTB right front fog light.
    By roc64 in forum BMW Parts Wanted
    Last Post: 03-26-2002, 02:50 PM
