RM European Auto Parts
Results 1 to 9 of 9
Thread: Help me name that line
    Mar 2019
    Georgia
    325Ci
    There’s a vacuum line with an unknown connection right behind my intake manifold. It’s located on the top side of a connector that extends from the wiring harness all the way across over to what appears is the second air pump. Does anyone know what this vacuum line connects to?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Built year/month, model? Did you check in realoem? http://www.realoem.com/bmw/select.do
    My Cars: 325Ci
    please add the details = Built year/month, model
    Mar 2019
    Georgia
    325Ci
    2002 325Ci
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    It connects from the secondary air valve to the secondary air control solenoid.
    Chris Powell
    BMWCCA 274412
    Mar 2019
    Georgia
    325Ci
    The secondary air valve side is connected. The vacuum line is about 6 inches long and less than 1 cm thick. Would that connect to the backside of the intake?
    Mar 2019
    Georgia
    325Ci
    And could this also cause a slight rattle at idle only? Noise wasn’t there before working on the car. Replaced intake manifold gasket and PCV valve which got rid of misfires and stalling. Only issue now is slight rough idle and the duh-duh-duh-duh noise that goes away when accelerator is depressed.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The first step in diagnosing a problem is to scan the car for codes.
    Mar 2019
    Georgia
    325Ci
    No CEL
    No CEL is different that not having any stored codes. There are codes that can be stored without turning on the CEL.
  1. Help me name a song
    By Evan e21 in forum Off-Topic
    Last Post: 07-22-2003, 12:23 AM
  2. Help me name my new dog
    By wolfsburg02 in forum Off-Topic
    Last Post: 05-06-2003, 02:15 PM
  3. Help me name my detailing business!
    By Kyle K. in forum Off-Topic
    Last Post: 03-19-2003, 11:44 AM
  4. Help! ZKWs...are they lined up
    By ///M LIFE© in forum 1992 - 1999 M3 (E36)
    Last Post: 03-12-2003, 05:11 PM
  5. help me name my business
    By bmwparamedic in forum Off-Topic
    Last Post: 09-14-2002, 12:05 AM
