Results 1 to 7 of 7
Thread: Dash lights won't turn off help!
    Jan 2019
    Roselle, Illinois, US
    2000 bmw 740I 93k
    Hey guys so my engine light, brake and abs lights came on along with the traction control light I was told it would be my wheel speed sensor I replaced the passenger rear as one wire of the sensor was cut, the only light that turned off was the check engine light. Can anyone help?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    First of all you need diagnostics to check what errors you have - but most likely you have the usual DSC module failure as described below:
    https://www.meeknet.co.uk/E38/ABS/Index.htm
    My BMW Repair YouTube Channel
    Jan 2017
    North Carolina coast
    2001 740iL Prod 4/2000
    +1 on Timm's advice. For a while I had intermittent cruise control dropout with the 'trifecta' of lights immediately after.
    Since the cruise signal reads from the right rear, makes sense to replace that sensor? Uh...no.
    Set up INPA after a bit, and found 208 instances of the left front wheel speed sensor dropping out. Sometimes diagnostics on
    these cars are no so intuitive, given the range on connectivity they exist on.
    Accurate diagnostics and INPA are your friend.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The problem is the little gold wires that are spot-welded between the PCB and the PCB-substrate - the picture below shows where I had a go at re-soldering the connection at the bottom centre:
    This is the same repair that Module-Masters and other repairers make. The little wires get signals from the wheel sensors, pressure sensors and all sorts of other things. When they fail you will get an error code that references which wire has fallen off (such as a wheel sensor) - but the fault is with the DSC module.....
    Jan 2019
    2000 bmw 740I 93k
    Also my speedometer is not working and ran out of gas on the street because fuel gauge is not accurate could this be caused by the same thing
    Jun 2008
    Atlanta, GA
    E53, E38, E34, E39T
    Sounds like a bad ABS module as stated above. Also, as Timm said, best to scan the car with OE software for verification.
    Some Places remain unknown because no one has ventured forth. Others remain so because no one has ever come back......
    Jan 2019
    2000 bmw 740I 93k
    Took it to my local shop in roselle IL and it ended up being another speed sensor thx guys ��
  1. 2003 BMW X5 Dash Lights won't turn off, weird buzzing sound
    By blloyd29 in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 07-25-2015, 07:09 PM
  2. Bought new headlight lights and they won't turn on. Help!
    By Married 2 the 7 in forum 2002 - 2008 (E65, E66)
    Last Post: 11-09-2014, 01:19 AM
  3. Tail light dash indicator won't turn off
    By davebrown104 in forum Lighting sponsored by BAVToys
    Last Post: 03-08-2011, 09:36 PM
  4. Fog lights won't turn on after Euro ellipsoid install
    By SiOrange in forum 1988 - 1996 (E34)
    Last Post: 09-21-2003, 06:40 PM
  5. Brake Pad Light WON'T Turn OFF
    By mini///m3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-21-2002, 10:45 PM
