Results 1 to 8 of 8
Thread: Motor Mounts
    Jul 2012
    California Inland Empire
    2001 740iL /1991 E32
    Motor Mounts
    So this won’t be anything new to many but I just replaced my engine motor mounts. Can’t believe what a difference it made or the condition the old one were in. Engine sits much higher now as evidence how much I had to raise engine to put the new ones in. Check them motor mounts.
    2001 740iL Guides,chains,vanos done. Full steptronic retrofit,3:15 diff. DUDMD tune. Sport seat retrofit. Porn lights
    [IMG][/IMG]
    Nitto ZR 285/40/18 rear 245/45/18 fr. UUC springs front. Porn lights. Sport wheel
    1991 735iL UUC springs front only Style 42 wheels
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Quote Originally Posted by haynes740 View Post
    Also much less vibration
    Jul 2012
    Yes forgot to mention that thanks.
    [IMG][/IMG]
    Nov 2017
    DFW
    1999 740iL
    Now you probably need to replace your transmission mounts. With the engine sitting up higher, and your transmission likely lower than designed, the angle between the trans and the driveshaft will be off. That will tear up your guibo disk in a hurry.
    Jul 2012
    Quote Originally Posted by gusdog View Post
    Did that last week that’s what caused me to examine the motor mounts. All is well now.
    [IMG][/IMG]
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Changing transmission mounts was the worst job for me on this car. Hated it!
    Houston, Texas
    1995 Dinan 740il
    How did you know they needed changing?
    May 2013
    Rochester, NY
    2001 740i Sport
    Quote Originally Posted by Grady in Texas View Post
    Trans mounts will look squished as they age. Motor mounts can look torn or start leaking (they're fluid filled). And realistically, if they're original, it's probably a safe assumption that they need replacing at this point.
  1. Motor mount question
    By M-tinker in forum 1992 - 1999 M3 (E36)
    Last Post: 04-28-2003, 03:57 AM
  2. Is there an Aftermarket motor mount?
    By CrayzeeM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 04-24-2003, 03:24 PM
  3. Motor mount bracket?
    By mp318is in forum 1992 - 1999 M3 (E36)
    Last Post: 03-28-2003, 03:35 AM
  4. Replacing motor mounts
    By zeit00 in forum 1983 - 1991 (E30)
    Last Post: 03-01-2003, 10:23 AM
  5. Is this a motor mount?
    By BS05ZHP in forum 1992 - 1999 M3 (E36)
    Last Post: 04-29-2002, 12:53 PM
