Results 1 to 8 of 8
Thread: how much brake fluid is lost when replacing the brake line and caliper.
    Mar 2018
    Milford, CT
    03 540iA/16 435 F33
    I believe I need to rebuild a rear caliper so I'm going to replace the original brake lines at the same time. If I don't remove the cap on brake reservoir, should I expect to loose a lot from the system? I understand I need to bleed the system after but I've never pulled off a caliper.
    Apr 2017
    London, UK
    E30 Turbo, E39 530d Tour
    Quote Originally Posted by scubajim20 View Post
    You'll likely introduce air into the system when you remove any of the lines, so you'll need to do a complete bleed.
    If you're rebuilding one, you'd be better off rebuilding in pairs (both rears).
    A full bleed is about 1.5 litres from what I've read.
    Sep 2010
    Corpus Christi Texas USA
    850ci, M5, Alpina B7
    Leaving the cap on won’t save anything.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    The cap is vented.
    Get a small plug or tapered rubber cork to stick in the open line as soon as you disconnect the flex brake line from the hard line. That will minimize the loss and air getting in.
    When's the last time you replaced all the brake fluid? If it's been 4 years or more then all of it should be replaced.
    If your just interested in the volume for that one caliper and line it's about 4 ounces.
    Make sure you use flare wrenches so you don't round the corners of the fittings!
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    Tip/Trick, push the brake pedal 1/2 way, wedge a piece of wood between the seat and the pedal to keep it there and presto, no fluid will leak out as you work. The alternative to to plug the hard line as your work, if nothing is done all the fluid will leak out as you work. Buy two qts of Brake Fluid Type 3/4. My personal choice is ValvolineDOT 3 and 4 Brake Fluid (32 oz.) https://shop.advanceautoparts.com/c3...rs-fluid/16113
    Don't forget to clean and install DRY the caliper pins, apply caliper grease to all pad contact points, replace the pads, and replace the rotors (they are cheap!)
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Omaha, NE
    1998 528i 5-spd 102K
    Search for the caliper and 6 hoses rebuild I wrote in forum using FTE seals/boots.
    Get all 6 new hoses and do them all at the same time.
    Clamp the old hose to prevent fluid loss.
    Once the caliper is rebuilt, replace the hose.
    Mar 2018
    Milford, CT
    03 540iA/16 435 F33
    Thank you all great advice. I had done all the brakes and rotors over the last 8 months but on quick inspection my right rear caliper ate one pad so I need the rebuild. I will rebuild backs, change hoses all around and flush the system.
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    PERFECT plan!
    2003 525iT TiSilver
    2002 M5 TiSilver
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
  1. low brake fluid caused the dreaded abs+asc+brake
    By pegcity in forum 1999 - 2006 (E46)
    Last Post: 05-27-2010, 01:34 AM
  2. How much brake fluid is needed to flush and replace the brake fluid?
    By 96INFMSM3 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 12-03-2005, 01:54 PM
  3. Replacing master cylinder - 1liter of brake fluid enough?
    By Robert in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-18-2005, 02:16 AM
  4. brake fluid flush/replacement -under warranty?
    By fmk in forum 2001 - 2006 M3 (E46)
    Last Post: 03-10-2005, 11:08 AM
  5. How often should I replace my brake fluid?
    By Hornswoggler in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 11-22-2003, 05:15 AM
