Results 1 to 14 of 14
Thread: Camshaft position sensor frequent failure
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Hello everyone
    I recently did replacement of timing chain guides , after few weeks on , the engine is knocking , stalling after hot start and has decrease power .
    by using inpa there is fault code of camshaft sensor , I replaced it with used good one ( IMG_2848.jpg ) the car runs great but after about 2 weeks it starts to knock and lastly stall
    the code also shows cam sensor .
    I see the wiring it appears very good but I do not know what is the plastic end is these wires shows in images ?
    Lastly is it a bad luck or there is another problem regarding the cam sensor ? IMG_2846.jpgIMG_2847.jpg
    May 2009
    Lithuania
    E38 750i FL & E36 M3 4DR
    I have no issues with engine starting and running, but while ago I started getting CPS sensor error when diagnosing the car. Each time the error is cleared it comes back straight away.
    What I did, I have purchased brand new OEM BMW CPS sensor and replaced it, but the error is still appearing.I get error as below.
    Camshaft Position Sensor - value not plausible.
    I do not really know what to check next. Any ideal folks?
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The OP needs to check the adaptation values and other data as explained here:
    https://www.meeknet.co.uk/E38/Diagnostics.htm
    ....as knocking is very unlikely to be caused by the camshaft sensor - much more likely to be due to a blocked catalytic converter.
    Where you get a 'Camshaft Position Sensor - value not plausible' error it more likely to be due to a camshaft timing error
    My BMW Repair YouTube Channel
    Mar 2014
    Iraq
    1998 BMW e38 740i
    I read the code of cps but not sure about pulsation I will photograph the german terms , the knocking after guides replacement not precent . It appears after a while
    Sent from my iPad using Tapatalk
    Aug 2017
    Wayne,PA
    740iL (E38 '01)
    Could be timing wheel issue as well, considering that you just did the guides. I would put the engine in TDC and check the timing wheel thru the inspection holes on the upper timing covers.
    May 2009
    Lithuania
    Would that mean engine needs timing done? Or is there any other way to solve this?
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Here is the error
    The adaptation values are bank 1 : -1 additive ,+ 5 multiplicative bank 2 :- 2 additive , + 7 multiplicative
    Mar 2014
    Iraq
    1998 BMW e38 740i
    The third sensor has the same issue , works fine for one day ( no codes ) then the car dies after each start with the previous code .
    May 2009
    Lithuania
    Update on my post above: I believe I have fixed the issue by refitting the sensor. Today in the morning I went to the garage and inspected how CPS was fitted and it appears, that bolt was not tighened enough, there were about 2mm of the screww thread left and seal of the sensr itself was visible. So I have removed the sensor, fitted it properly and tightened the bolt so that there no gap left. Drove the car for a day and scanned with INPA in the evening. Fault code was gone and did not appear again.
    Conclusion - camshaft position sensor is very sensitive to fitting and even 2mm tolerance in tighening it is not allowed. Happy with that
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Quote Originally Posted by exeed View Post
    Nice review I will try this and inform you
    May 2009
    Lithuania
    Quote Originally Posted by haydar alameen View Post
    Pictures alwys speak million times more than words.
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Unfortunately it dose not work
    Mar 2014
    Iraq
    1998 BMW e38 740i
    Quote Originally Posted by georgebest View Post
    I visit the mechanic shop , regarding the timing there is no any error , the plate is in correct position
    Mar 2018
    Stockholm, Sweden
    2000 750iL, 1989 320i
    Did you find out the problem?
  1. Camshaft position sensor, multiple failures
    By Xoloski in forum 1991 - 1999 (E36)
    Last Post: 10-19-2014, 04:39 PM
  2. What's the camshaft position sensor failure symptom again?
    By JoshS in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 09-01-2014, 08:22 AM
  3. camshaft position sensor failure
    By chellymally in forum 1991 - 1999 (E36)
    Last Post: 04-01-2014, 10:24 AM
  4. CAMshaft position sensor circuit failure
    By 3ggshell in forum 1992 - 1999 M3 (E36)
    Last Post: 11-19-2013, 08:05 PM
  5. Camshaft Position Sensor Failure?
    By mindphlux in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-15-2011, 02:50 PM
