RM European Auto Parts
Results 1 to 4 of 4
Thread: Bent Valves, Exhaust Side
    Aug 2018
    Watsonville
    97 M3, 97 328i, 95 318ti
    So today the machine shop told me that my exhaust side valves were bent in a S bend. which looked like they bent and something or someone bent back to make them work. There was no noise or any engine problems, no misfire, no low compression, not even a check engine light. nothing!!! so when i heard this i couldn’t believe it, so i’m here to see what people can see what went wrong maybe, or something that happened while i was pulling off.
    Thanks!
    Valves don't just bent, unless they hit something like the top of the piston. And once they're bent, there is no fixing them. Why is your head at the machine shop anyway? Overheating?
    If you set the head down on the mating surface, with the cams still in place, it is possible you bent them. With the cams in place, some of the valves would be open. In theory, if the cams were out of the head, all the valves would have been closed and wouldn't be possible to bend any.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by S.C.B.I.M.M.E.R View Post
    Thanks!
    No way that engine ran well with bent valves. So, why is it dismantled and at the machine shop?
    Valves "bent back to make them work" What is your machinist smoking?
    To answer what I think is your question. How did this happen? The engine was over revved.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    A mechanical over rev is possible, and I agree that the engine would not run perfectly unless maybe the bend was very minor. It is also possible the OP damaged the exhaust valves when removing the head if he rotated either the cams or crank while the timing chain was not connecting them.
  1. Q: Bent Valves?
    By Dre in forum 1991 - 1999 (E36)
    Last Post: 03-12-2003, 06:55 PM
  2. Wanna see some bent valves?
    By snk328is in forum 1991 - 1999 (E36)
    Last Post: 02-06-2003, 05:13 PM
  3. Got a question about bent valves/misshifts
    By ScottDetroit in forum 1992 - 1999 M3 (E36)
    Last Post: 07-24-2002, 02:49 PM
  4. # 3 Missfire- BMW says bent valve
    By ultim3 in forum 1992 - 1999 M3 (E36)
    Last Post: 05-23-2002, 03:35 PM
  5. what to expect from bent valve?
    By bmwada2ud in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-01-2002, 10:24 AM
