Results 1 to 16 of 16
Thread: Changing springs & shocks
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    as a shock is leaking i tought it was time to change shocks and springs also, because i found the car to low as i bought it . Hitting speed bumps with the front spoiler was no rarity.
    I bought a "sport" set : Eibach springs and Bilstein shocks.
    This evening was for the rear … shocks are easy to remove , springs were more complicated. I think i have H&R in it ( red and low ) but the ST couldn't pass between windings. Old springs are 16 mm diameter, Eibach 15 mm. Eibach is approx 20 mm longer in total length , both have 8.5 windings. So on the old ones the windings are much closer together.
    I managed to remove the old springs by compressing them with a jack and secure them with tension straps. Just enough to get them out. I could loose them again by compressing them under the lift ….On the new ones i could use the ST.
    I had to order new oem dust caps and bump stops for the rear as those are not in the set. Should be in tomorrow.
    Next are the fronts….
    Sep 2018
    Belgium
    almost 100 peeps but no new clues how to remove rear springs without the ST....
    Well, all is back together in the rear , tomorrow i can start on the front.
    OEM dust covers were not that easy to get the big washer in the groove ….. even with heat.
    As for now i see the rear 2 cm higher …. that's already good !
    Sep 2018
    Belgium
    Lucky the Bilstein's have the gland nut … so the old one can be broken…. dremel, heat and hammer… 15 min work.
    don't think it would be easy to get that s*cker loose in 1 piece ….
    time for camber plates….
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Used my Dremel with cut off wheel on the 850 last night also.
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I did not have an easy time removing the rear springs, either! IIRC, I disconnected inboard side of the upper wishbone and used some spring compressors to wrestle springs off of suspension. I have a modified suspension in car now with shorter springs that are a breeze to remove. I am also using front adjustable camber/caster plates from Ground Control. They were actually designed for an E36 so they had to be rotated 90 deg but they work just fine.
    Sep 2018
    Belgium
    nice JDP530 ! ... but for yearly tech inspection here , setups like you have are not allowed. I can "risk" the camber plates , normally you "almost" don't see that. Those plates give 2° extra neg camber. Looking at your pic , you have more
    Sep 2018
    Belgium
    done the left side this evening... no better, even with the right hand side experience. It stays a almost 30 years old car and nuts have grown on bolts.
    I hope to get it good… those Bilstein gland nuts just don't screw that easy on the struts… i have to carefully clean them and break in with a turn forward / a half a turn back. And a lot of oil. I suspect a lot of work before they tread on normal .... corrosion ? out of round deformation in the years ? who knows…. I must sure get the nuts good rotating on the strut thread before even installing the shocks with them…
    Mar 2011
    Liberal Loontown, CA
    Cool Volvo, Ugly BMW
    There is a tool for the gland nuts on the Billies. Bilstein sells them for very little money and it helps quite a bit.
    What "thumbs up" really means
    Sep 2018
    Belgium
    been to the autoparts shop but not that tool for the gland nuts... i have several ( for adjusting height) , but those are all to big.
    Forgot to go at a bearing supplier…. conical bearing tensioners have those nuts to , so the wrenches….
    Apr 2009
    Ridley Park, PA
    91 850i x2, 92 850i 6sp
    I think I may be the only one that didn’t have much trouble with my gland nuts. I just soaked them with WD-40 and grabbed the largest pipe wrench I could find. Gave it all I got for about a min on each and they budged. My biggest headache ended up being a mushroomed sway bar link bolt.
    Sep 2018
    Belgium
    I remembered i have a wrench as for oil filters but with a chain ( no leather strap ) … that one works perfect on the Bilstein gland nut without any damage. It's made in the USA
    Surface corrosion has worked his way until half way the thread.... i must search for a "safe" cleaning method. One side already turns full on , other side i don't get the nut started… will look tomorrow if i can make myself something like that : THREADBOY1.jpg
    Sep 2018
    Belgium
    couldn't wait for tomorrow, so i got along this evening …. i got them both turning ! cleaned the corroded part with a wire wheel and got the nut started… after that a lot of turning in/out with penetrating oil. 1 turn break in by the time , no use to try more. Remove , clean , oil and start again. That way it was working . Glad i succeeded, or it was $$$$ new struts… after all surprized how corroded those oem gland nuts / thread were . Must say , the dust boots were closed at the bottom but no more at the top... so a perfect water trap once the drain in the spring plate is full of debris….
    curious for road handling as all shocks were shot ….can only be much,much better
    Sep 2018
    Belgium
    a year ago i renewed the master cilinder ... brakes were "sticking" . That is the result... will be better now
    always amazed what we gather around a working spot …
    Sep 2018
    Belgium
    finished ! car is again on his wheels and yes, a 2 cm higher with the Eibach's compared to the H&R.... me happy.
    The ENGL camber plates are not visible… it is only 2° ...
    so this for the iron scrap…
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Shock Removal
    Did this to my truck this weekend to get the shock out.
    Sep 2018
    Belgium
    difference in height isn't that much noticable .... but better for speeds bumps . Now that all is settled , it must be 1.5...max 2 cm.
    H&R ----------------------------- Eibach
  1. Changed Springs/Shocks. Now She Sits Uneven?!
    By UKFan4Sure! in forum 1983 - 1991 (E30)
    Last Post: 01-22-2009, 08:37 AM
  2. Stock shocks - Just change springs?
    By jLace in forum 1996 - 2003 (E39)
    Last Post: 06-01-2008, 06:54 PM
  3. Replies: 13
    Last Post: 02-28-2005, 06:10 PM
  4. Can I just change the springs and shocks?
    By raulpou in forum 1991 - 1999 (E36)
    Last Post: 06-02-2004, 01:37 PM
  5. Changing Shocks: Change Springs?
    By dave162 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-11-2004, 01:48 PM
