Results 1 to 9 of 9
    Mar 2019
    NY, New York
    2012 BMW X5
    Color Temperature of OEM low beam for 2012 X5
    Hello All
    First post here so hello to everyone and my apologies if this has already been answered.
    I've been searching all over the internet and even called my local BMW parts department who couldn't help me. SMH..
    Simple question, does anyone know the color temperature (ie 4300K or 6000K etc..) of the OEM BMW Xenon low beam for the 2012 X5?
    I know the part number is 63 21 7 217 509 but cant seem to find the color temp info.
    Does anyone know?
    DAC
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to X5 forum
    This may be totally irrelevant, but why do you want to know the color temp? Are you trying to match it with an aftermarket part? Just curious as to what your intentions are.
    Jersey City, NJ
    2013 X5 35i M-Sport
    OEM is usually 4300-5000k.
    If you are trying to match a new bulb to an existing bulb, dont bother as even if the temp is the same, the color will be different because of age. Replace both bulbs
    VRSF CP & DP | BMS Intake | MHD 2+ Tune | BavSound Stage 1 | 20% Tint
    Contact me for module coding/ECU resets
    Mar 2019
    NY, New York
    2012 BMW X5
    @White94RX Yes, I wanted to match the color of the bulb.
    @Ryan's BMW I actually agree with you on replacing both. I was about to pull the trigger on purchasing the Osrams Night Breaker until I saw color temperature and wasn't sure if it was the same color as my original bulbs. These Osrams are 4200K.
    This is the first time I'm purchasing bulbs (low beams) for my 2012 X5 xdrive35i.
    Do you guys have any recommendations regarding the type of bulbs I should purchase?
    Thanks for your responses btw!
    I would buy OEM only. And I think Osram is the original supplier to BMW.
    Mar 2019
    NY, New York
    2012 BMW X5
    Thanks for the reply.
    I almost died when I heard $235 for a bulb. Arrgh..
    Do you think I'll be ok with the Osram?
    Mar 2001
    STR, MUC, LHR
    I love turbos!
    AFAIK, BMW does not make their own bulbs. Instead, Bosch, Osram, Sylvania or Philips make the bulbs for them. Any of those brands would be good and Pelican has them ranging in price from $65 to $95. Genuine BMW is $173.
    Jersey City, NJ
    2013 X5 35i M-Sport
    Osram CBI seem to set the bar for light output. But anything from Osram or Philips will work just fine in terms of quality
  1. What is the Low beam fuse rating for oem HID?
    By tschangrx7 in forum 2001 - 2006 M3 (E46)
    Last Post: 05-27-2006, 10:03 AM
  2. Color configuration for high/low beams
    By M3Romeo in forum 1992 - 1999 M3 (E36)
    Last Post: 05-19-2005, 05:34 PM
  3. COLOR MATCHING halogen high beams to 6000K HID low beams
    By 96328is in forum BMW Rides & Events
    Last Post: 01-14-2005, 07:38 AM
  4. 9006 Low Beam OEM for Free
    By pghguy in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-21-2004, 09:42 PM
  5. F/s: OEM BMW Hid Bi-Xenon Projectors - High and Low beam!!
    By 95MMM in forum BMW Parts For Sale
    Last Post: 08-10-2003, 10:39 AM
